If the set up that Chris L above has suggested doesn't work then the problem lies with the fit of the reduction gearing. The build instructions stated the joints involved were to be loctited but either one or of those joints is now probably slipping
I had exactly this problem on mine drilling holes approaching 20 mm diameter and you could hear churning noises from within the gearbox. I wrote up my fix in MEW 315
Regards Brian
