Sounds like a design error. Bearings are almost never the same metal both sides. Tends to rub, get hot, gall and seize.
Best practice is for a hard shaft to run in a soft bearing shell, two different materials, with lubrication. Lots of combinations don’t work, such as steel and aluminium. Others work extremely well, like the hardened steel pivot and ruby found in mechanical watches. Easier to copy what others have proved works than to experiment.
Steel in cast-iron is OK for lightly loaded slow turning bearings because most cast-irons are full of slippery graphite. Popular in old sewing machines, many still in good order a century later.
Bearing shells were originally called ‘Brasses’, because they were made of soft brass, the shaft probably being wrought iron, and lubricated with tallow or animal fat. Brass is a reasonably good bearing metal for steel, and with a little oil will take moderate speeds and loads. Bronze will take a bigger beating than Brass.
So far, these are all Plain Bearings, which aren’t ideal, even when souped-up with White Metal and a high-pressure oil pump. They work by the shaft riding on an oil layer, avoiding metal on metal as much as possible. Unfortunately metal on metal occur when the shafts in plain bearings stop and start, and – much worse – if high speed or an excessive load breaks the oil layer. `
Plain bearings run within their limits take decades to wear out, but running them too fast takes years off their lives.
The main disadvantage of plain bearings is they are high-maintenance. Gone are the days when a sailor would spend a watch next to a propeller shaft to make sure a bearing was OK, constantly checking the oil, and periodically hosing it down with sea-water to keep it cool.
Roller and taper bearings have mostly replaced plain bearings because they can do high loads and high speed, don’t need TLC, and are replaceable.
For lightish duty, almost all my home-made bearings are Steel running in Brass with a simple oiling hole that I must remember to keep topped up. A more sophisticated variant would be an oil bottle with a wick or needle. A cast-iron bush is an alternative, but I avoid cast-iron because of the dirt. Oilite bushes are an option too.
