Dont ever buy one of these
Home Forums Hints And Tips for model engineers Dont ever buy one of these
  • #104912
    Robin teslar
      @robinteslar
      I bought this on Ebay, new, said it was a Rolson grease gun (£6.50?). I spent all afternoon wrestling with this very nasty piece of kit.
      Firstly the grease packing spring was so strong I couldnt manage to screw it together and had to chop a third off to get a reasonable try.
      The ratchet was flimsy and unreliable, meaning it would spring open without warning – dangerous
      The so -ccalled bleed screw was very bad, no warning that if you continued to screw it in expecting to hit a seat it just carried on through into the cylinder, and allowed grease to spew out, very nasty and fiddly to get it back in to its thread.
      Very difficult to bleed, still not right
      I shall probably bin it, cant be bothered to raise a complaint and send it back, already wasted so much time on it.
      Anyone know a reliable grease gun – I just took these things for granted
      A cheap chinese fake
      Grrrrrrr
      Robin teslar
        @robinteslar
        Nasty grease gun
        #104916
        KWIL
          @kwil
          Rolson, need I say more!sad
          #104918
          Terryd
            @terryd72465
            Hi Robin,
            That is similar to a Wanner gun which I used to have, but they cost – around £60 to £70 for the basic gun. Re the spring, it is usual to tension the spring with the loop at the bottom , itshould be attached to a chain (or is that the 'ratchet' you mention?) which pulls the pressure piston down the loading tube so that the top can be removed to pack the grease in. It needs to be extra long in order to pressurise the grease. You should be able to pull it down and lock the spring tight with the chain (by twisting a link) if it's there, then you can screw the top off and load the grease, you don't release the spring until the top is back on.
            The 'bleed screw' is to release the pressure when the gun has locked on to a nipple which is what these type of guns should do when being used. Otherwise you would not be able to release it from the nipple. Hope that helps
            Best regards
            Terry
            #104923
            Andyf
              @andyf
              Like Terry, I bought a Wanner. That was over 40 years ago, and it still works fine.
              Andy
              #104926
              The Merry Miller
                @themerrymiller
                I bought mine in the early '60's when I used to do my own car servicing, it was a "Rom-Pom" gun and I've just found out that my son-in-law has it and has never used it.
                Well it's on it way back to me as I write (hopefully). See image below.
                Len. P.
                Edited By The Merry Miller on 28/11/2012 19:19:39
                #104930
                Sub Mandrel
                  @submandrel
                  Cheap? Yes!
                  Chinese? Yes!
                  Fake? Hardly – genuine Rolson Qulaity Tool by the sound of it.
                  That said, some Rolson stuff is great for 'semi disposable' or 'one shot' use because it is so cheap. I'd tow a car with their carabiners, but I wouldn't take one rock climbing =:-0
                  The wire stripper/flush side cutters are very crudely made but work brilliantly – I bought a new pair when I lost the first!
                  Robin teslar
                    @robinteslar
                    Agreed SM
                    Ive had some acceptable Rolson stuff, but this was attrocious.
                    Yes the Chinese can fake Chinese
                    Things they do dont bear thinking about, rememer the cell phone batteries that blew up cos they didnt have a charge control chip
                    Cheers
                    Robin
                    #104953
                    Sub Mandrel
                      @submandrel
                      Best yet '500 GB Hard drives' witha 1GB USB stick and asome junk steel inside.
                      Gordon W
                        @gordonw
                        One thing I've found with cheap? grease guns, you have to use a cartridge to work properley, they won't work by packing with loose grease, which good ones will. A nuisance with special greases.
                        #104989
                        DMB
                          @dmb
                          Guy Lautard wrote an article on modifying a cheap gease gun to a very good oil pumper. I think it was in one of his books on engineering/related topics.
