Morning all.. this isn't today's planned pictures.. this was in response to a couple of questions from a fellow ME down under and I thought others may be thinking the same thing, so I've copied/pasted my reply to here.
Don's design is more or less a true miniature of full size, both in looks/design and in how the various parts work, the lubricators are an example which I'll cover at the end with some pictures. Due to the complexity of this model and my limited time in this world I have tried to build it where I don't need to keep taking things apart, or at least to greatly reduce this. If I had got her to the running stage without first making all of the brake and sanding gear it would have made things much more time-consuming. As an example, the gravity sanders had to be done before the cylinders and their slide bars were fitted, it made sense to also make all of the rod linkages to the cab at the same time and test. The same goes for the steam sanders, vacuum brakes etc. This has a knock-on effect, such as the cab needed to be at least made to a basic stage which it currently is. there are so many parts (all working) to the model that it gets a little bewildering sometimes. I would love to have it running on air, I am getting closer but still have a fair bit to do first, the lubricator drive arm and connecting rods being such an item.
Yes, the boiler will be fed by two injectors, there are no handpumps or axle pumps on this model. There will, however, be a backup water feed method. The boiler will be filled via an electric HP 12v pump. Not only will this fill the boiler from empty pretty quickly but it will also be an emergency method of replenishing the water if both injectors fail, the pump will be capable of overcoming 130 PSI which gives a good safety margin against the working boiler pressure of 100 PSI.
Finally the lubricators and whether any provision has already been made for them, You'll be happy to learn the answer is yes, I'll post a few pictures to show where we are and how things will work.
First up is a picture of where the forward lubricator sits, I have placed one of Adam's superb castings to give a general idea of how it will look. This will be a fully working lubricator, I'll work out the internal design later. This sits exactly where it does on the prototype and will be connected to the valve gear in the same way. A few things to point out, the front lubricator sits very close to the gravity sander linkage, also in this picture, you can see the 10 BA CSK screws which are practical, all the others are sealed, this makes future maintenance much easier although still a lot of work if needed to remove the running boards etc. These particular screws will be changed for newly painted items on final assembly. bTW this particular lubricator will feed the 3 cylinders, as per full size
Next is the rear lubricator position, this one will feed the 3 main driving axle boxes, their axles and horns, again, as per full size. The slot to the front is for the operating arm to drop down through to connect to the rod linkage below. Also of note here is the close proximity of the steam sander filler neck, I secure its lid later, it's already made.
Lastly, a close up of the spigot that's part of the R/H expansion link shaft, the drive arm will fit this spigot and have two connecting rods from it to the two lubricators fore and aft of this position.
Hope that answers all questions…
Pete
