Hi Greg
Sorry I have only just noticed this thread. I am also (slowly) building Don Young's Derby 2P (Very similar to the 4F) and have just run the chassis on air.
I can confirm that the two most difficult bits are the Joy valve gear slide and the crank axle.
I milled the Joy slides from a piece of gauge plate mounted on the end of a length of steel bolted to a rotary table.
This is easy enough provided you have a vertical mill. You can buy a gunmetal casting to produce the slides in the lathe but this is ridiculously expensive nowadays. The most difficult task is holding the assembly together for silver soldering and Don made a couple of mods on the 2P to make life easier. These are detailed in his Locomotives Large and Small magazine No 26 February 1986.
First the slideshaft which holds the assembly together is moved from the middle of the slides to the top and the holes for the fulcrum pins are carried through on all four slides so that a temporary piece of silver steel can be inserted to facilitate assembly. Silver solder the slideshaft first, clean up remove the holding bar and fit the fulcrum pins last. My fulcrum pins were silver soldered by a good friend with a oxypropane set but I see no reason why they should not be held with Loctite 603.
I did use retaining grade Loctite on my Crank Axle but I can't really recommend it. I have rebuilt the crank axle twice now as it has fallen apart twice. The first time the joint was broken by a sliver of corrosion in storage and the second it simply failed when air testing. These are all really issues with my workmanship NOT the Loctite which is theoretically quite adequate. The latest iteration is still loctited and fitted with rollpins in each joint. If this one gives up I will have a go at silver soldering one.
I think that there are two basic problems with using Loctite. The first is that the joints must be very clean and the second is that we tend to have insufficient clearance in the joint so most of the Loctite is wiped away on assembly.
A remaining decision is the smokebox door as Don's design is not as the Midland prototype with multiple "dogs" around the outside. I have not decided what to do about this yet.
Finally, just a recommendation from my own mistakes. It would be wise to not make a final decision on the next model until you have steamed the Tich at your local track a few times; this experience may well modify your thinking!
Good Luck with the build.
Adrian
