Does This Impress You?
Home Forums Workshop Techniques Does This Impress You?
Viewing 25 posts - 1 through 25 (of 53 total)
  • #86395
    Alan Worland 1
      @alanworland1
      I am always amazed at the amount people who are impressed with the alignment of screw heads in various items – the most obvious of which would be hinges/handles fittedto doors by a 'carpenter.
      This indicates to me that either the screws have been over tightened or under tightened to achieve alignment!
      Doesn't impress me, in fact it does the opposite!
      I feel better for that
      What do you all think?
      Alan
      Alan Worland 1
        @alanworland1
        #86396
        MAC
          @mac53652
          Not impressed, I just think it looks better – and will continue to do it (on door fittings that is).
          I'm sure there are better things to worry about .
          #86398
          Springbok
            @springbok
            Try and get a "carpenter" who would go to that sort of detail these days they are like hens teeth whilst fitting a door, you will be lucky if he beds the hinges in properly. Though must say when I open a door do not inspect the hinges am I missing out on one of life’s experiences.
            Have a fun nice day in the workshop
            Bob
            #86399
            _Paul_
              @_paul_
              I must be the obsessive type as I do make them all line up, always slightly tighter never loose.
              How does one know when a screw is overtightened when tightening by hand? unless of course you use a torque wrench on them….but that would make you more obsessive than I cheeky
              Paul
              #86400
              John Stevenson 1
                @johnstevenson1
                Is this a freeking wind up ?
                John S.
                #86409
                Sam Stones
                  @samstones42903
                  Don't get the wind up John S, but here's another story.embarrassed
                  A couple of years before he retired back in the late 60's, my father changed jobs leaving a fairly large factory to continue being an electrician in the maintenance shop of a smaller establishment. The only other maintenance man was a (mechanical) fitter.
                  Not long after he started this new job, my father began to notice and to admire the very precise way in which the fitter went about any job he did, especially new installations. One task the fitter undertook was replacing existing factory wiring with fire-resistant pyrotenax cables. Every radius had to be perfect, every straight run had to be perfectly straight, and all the screw heads had to be at the same angle.
                  While making absolutely no difference to the performance of the factory, the fitter was obviously one of a dying breed, taking pride in the work he did.
                  Sam
                  #86410
                  Ed Duffner
                    @edduffner79357
                    When you work in a factory you tend to have more time to complete jobs. Cable radii are, or rather were determined by the IEEE reg's when I used to work to the 15th Edition and although I'd take my time getting cables straight and set a correct radius where required, I doubt I'd aline screw heads for pyro clips. I think that practice might border on an excessive compulsive behavior. smiley Time is money as the say, when you're a tradseman.
                    #86413
                    Donhe7
                      @donhe7
                      Posted by John Stevenson on 03/03/2012 23:38:14:
                      John S.
                      No, just Screwing with your mind ……….
                      donhe7
                      #86420
                        You will be hard pushed to find chippies these days aligning slots in hinges because We now use pozi headed screws, very rare to have slotted screws in hinges.
                        I will line up screws in door furniture/ironmongery if they are slotted and if brass & there is a risk of overtightening then try another screw until you get one that lines up without risk of snapping.
                        What anoys me more is the poor quality of a lot of screws supplied with even quite expensive fittings.
                        J
                        #86422
                        Terry Lane
                          @terrylane
                          To take a leaf out of the olde gunsmiths' book – to do it properly the screws should be regulated so the slots fall to the right position at the right tension.
                          #86423
                          John Coates
                            @johncoates48577
                            Just goes to show how the passage of time interprets the message differently!
                            When I read Alan's first post I had no idea what he was talking about
                            It was only when I got to Sam and finally Jason's posts that I understood we were on about aligning slotted screw heads
                            Mind you I am a young 'un of only 47 years old !
                            John Coates
                              @johncoates48577
                              Oh I've also just had to look up the definition of "tyro" having bumped into it frequently in early editions of MEW I am reading at the moment
                              embarrassed
                              #86427
                                You are still older than me Johnwink 2
                                #86428
                                Clive Hartland
                                  @clivehartland94829
                                  Is this not called, 'Finesse' doing a job to, the highest degree of excellence and finish?
                                  #86429
                                  Stewart Hart
                                    @stewarthart90345
                                    But how did they do it question
                                    I've pondered this one for some time having seen it on Mill Engines,
                                    My only conclusion is that they first made the slotted screws with over thick head, tightened them upon the engine, marked the heads somehow, then thined the heads down with new slots that would line up.
                                    Any advances on this.
                                    Stew
                                    #86430
                                    blowlamp
                                      @blowlamp
                                      Seeing the screwdriver slot thing would bug me because I'd know that he'd have had to over tighten the screws to get them to align.
                                      Like to have seen him do it with tapped holes into metal crying
                                      Martin.
                                      #86431
                                      Clive Hartland
                                        @clivehartland94829
                                        All old hat now as we use Skt/drive screws but years back I would have a job rejected if my slots were not all inline on an instrument side plates.
                                        It did slowly die out but the habit lingers on still to this day.
                                        I did it by screw selection as the slots were not all oriented the same to the thread. The screws were also sealed with wax to stop water entry.
                                        Now with various types of finish on the screws we have a lot of trouble removing them due to corrosion, interaction between the plating and the castings being the problem.
                                        Another problem with Cupro nickel screws was the heads popping off under tension.
                                        #86436
                                        John Haine
                                          @johnhaine32865
                                          “How does one know when a screw is overtightened when tightening by hand? unless of course you use a torque wrench on them?”
                                          Easy – tighten ’til it shears then back off half a turn…
                                          #86437
                                            Posted by JasonB on 04/03/2012 07:50:18:
                                            J
                                            When my new Workshop door was fitted, by a "Professional", I noticed that most of the nice Brass screws in the Hinges were badly damaged. … The screws are Phillips cross-point, but he had managed to drive them with a Pozidriv bit in a powerful electric Drill/Screwdriver.
                                            … You can imagine the mess that makes.
                                            It took me twenty minutes to explain that there is a difference !!
                                            Russell Eberhardt
                                              @russelleberhardt48058
                                              Lining the screws up was always done on high quality small boats. It was also done on guns, the purpose being safety – you could see at a glance if a screw was working loose.
                                              Russell.
                                              Edited By russell eberhardt on 04/03/2012 10:09:39
                                              #86441
                                                Yes Michael I hate that too. Its strange that the usual head for wood screws is Pozi but the brass ones tend to use Phillips which do look very nice when not chewed up.
                                                Easy remedy for those with screw alignment issued is to switch to Torx smiley
                                                #86443
                                                Bazyle
                                                  @bazyle
                                                  Posidrive/Phillips doubt if even 10% of the population know. There are some other variants too – we had a problem with some aircraft quality ones at £6 each
                                                  Adjusting head length is normal on clock screws – see many an article in ME.
                                                  Didn't Whitworth specify the handles on spanners (short) when he defined his thread system to make them monkey proof?
                                                  #86444
                                                  Stewart Hart
                                                    @stewarthart90345
                                                    Posted by russell eberhardt on 04/03/2012 10:09:02:
                                                    Russell.
                                                    You see something similar on lorry wheels with the yellow plastic tags,
                                                    Stew
                                                    #86446
                                                    Ian S C
                                                      @iansc
                                                      To fit a brass screw without marking it, first put in a steel screw, remove it, then put in the brass screw with a good fitting screwdriver. A lot of screws used here in NZ these days have Robertson heads, square hole, they seem to be easier to drive under power. Ian S C
