Does anybody own a Sieg Nano Lathe ?
Home Forums Workshop Tools and Tooling Does anybody own a Sieg Nano Lathe ?
Viewing 23 posts - 1 through 23 (of 23 total)
  • #157461
    Brian John
      @brianjohn93961
      Has anybody owned or used one of these Sieg Nano lathes ?
      There are some old reviews on the internet which were not very favourable but things may have improved since then.
      Brian John
        @brianjohn93961
        #157464
        Roderick Jenkins
          @roderickjenkins93242
          Might be better known as the Draper version
          Rod
          #157466
          Ketan Swali
            @ketanswali79440
            Bad copy…shizzle…lemon…nough said
            #157467
            Ketan Swali
              @ketanswali79440
              Not a beginners lathe…..not a watchmakers lathe….crap may be a good complement…ideal for Draper
              #157470
              Ady1
                @ady1
                Mentioned it a couple of years ago and no-one was interested
                A new "Unimat" on the block
                #157485
                Brian John
                  @brianjohn93961
                  Ketan : Have you used one or owned one ? Those reviews are quite old and they may have fixed the problems by now.
                  Ady1 : I searched this site before posting a new thread but could not find anything otherwise I would have added to your posting.
                  #157497
                  Ady1
                    @ady1
                    That's ok, I was only pointing out the total lack of interest in this new unit, which to my eyes looked like it had potential at the time
                    On the flip side, the unimat market is still very buoyant with lots of activity
                    #157498
                    victor mcconville
                      @victormcconville47638
                      Hi Brian John,
                      I do not have a Nano, I have a Sieg Baby C0 Lathe.
                      Which is about the same Size.
                      It was delivered 6 weeks ago, one day after ordering.
                      A test piece of S/S was turned down to 0.010" dia (.25mm dia) before it broke off.
                      The three jaw Chuck run-out was less than 0.002".
                      Although only 150watt motor I cannot stop the chuck by hand so the power is good.
                      The tail-stock alignment was out by about 0.004" (0.1mm)but can be adjusted.
                      The only problem was the way the carriage/cross slide is secured to the ways, but now after a bit of work is very good and robust.
                      The statements above were the areas where there is no information anywhere on the net and were my main worries before ordering.
                      In my opinion this lathe will be much better than the Nano mainly because any faults can be corrected easily.
                      I already have a full workshop, this lathe is for clock parts and use in the house in the cold Scottish winters.
                      any questions please ask
                      Victor J
                      #157499
                        Ketan is an importer of Seig products…
                        Brian John
                          @brianjohn93961
                          Victor : yes, I like the Sieg C0. It does look a better buy and it is not much heavier either. I will find an Australian seller to see what they are worth here. The Sieg ebay seller does not have a C0 which is why I had not seen it before.
                          Looks good :
                          http://www.ausee.com.au/shop/category.aspx?catid=46
                          Even better with an accessory pack :
                          http://www.ausee.com.au/shop/item.aspx?itemid=249
                          How do you fit a drill chuck to the tailstock ? Is this a thread unlike the other lathes which use an arbor ?
                          Edited By Brian John on 10/07/2014 09:41:02
                          Edited By Brian John on 10/07/2014 10:40:39
                          #157501
                          Ketan Swali
                            @ketanswali79440
                            Posted by Brian John on 10/07/2014 05:28:49:
                            I have not used or owned one. I have given one to an engineer for checking/testing. I had given the outcome of list of issues to SIEG. They disagreed. So we did not add to our range.
                            I am not prepared to go through the list of problems for various commercial reasons.
                            During the past two years I have meet two separate users who were looking for certain parts. They said that the machine needed 'a lot of fettling'.
                            Because of 'the look' (similar to watchmakers lathe), it also attracted a lot of interest from that particular hobby, because it is so cheap. However, it failed to meet the expectations 'for the price' of a well respected watchmaker who tested it out for us. His idea was to pitch it as an entry level machine to new people entering that hobby, but at the end, he agreed that the machine raised more questions then being able to address the need.
                            As a seller, I wish to invite as less or no problems post sales. At this price, there is no money in it for dealing with any user based issues.
                            Ketan at ARC.
                            #157502
                            victor mcconville
                              Hi Again Brian,
                              The drill chuck screws on to the tail-stock 14mm x 1mm external thread as does the three jaw chuck.
                              The live centre is a slide fit inside the tail-stock sleeve.
                              Victor J
                              #157509
                              Brian John
                                @brianjohn93961
                                Ketan : Thanks for the information. I cannot argue with your evaluation.
                                Victor : Does the three jaw chuck screw screw onto the spindle ? I am a bit confused here.
                                #157512
                                victor mcconville
                                  Hi Brian,
                                  The three jaw Chuck screws on to the headstock with an external 14 x 1mm thread on the spindle and an internal 14 x 1mm thread in the chuck, the chuck is located on a registered shoulder and gives the run-out on my chuck of 0.002" total.
                                  Hope this helps
                                  Victor
                                  #157518
                                  Brian John
                                    @brianjohn93961
                                    Isn't that unusual screwing the chuck onto the headstock ? I thought they all bolted on ? Can you still run it in both directions ?
                                    How does the face plate fit to the headstock ?
                                    #157519
                                      Not particularly, especially on older lathes and some new ones. Alternatives are bolt-on flange mount (cheap) and camlock (expensive). All depend for accuracy on an accurate register, and no way is inherently superior to the others for accuracy.
                                      Not a good idea unless you have an arrangement to stop the chuck unscrewing, as on the later Myfords.
                                      It screws on too.
                                      RJW
                                        @rjw
                                        Brian John & Victor, the Emco Unimat 3 has a 14mm x 1 thread on both the headstock and tailstock, so chucks and faceplates etc will fit either end, should fit the Sieg ok and widen the scope for tooling for you!
                                        Check RDG and Chronos etc, no connection just a very happy customer!
                                        John.
                                        #157563
                                        I.M. OUTAHERE
                                          @i-m-outahere
                                          Brian I sent you a P.M
                                          Ian.
                                          #158628
                                          Brian John
                                            @brianjohn93961
                                            I have sold the C2 and bought the Sieg CO lathe. Somebody mentioned earlier that the lathe should be bolted to the workbench rather than use the rubber feet. What is wrong with using the rubber feet ?
                                            Edited By Brian John on 24/07/2014 13:31:59
                                            #158632
                                            Andrew Moyes 1
                                              @andrewmoyes1
                                              Can I just correct a common misunderstanding here? The Myford 'safe reversing' feature on big-bore lathes is a misnomer in my opinion, as a user. The hole for the grub screw has a shoulder to stop the screw from contacting the vee groove in the spindle register. This is so that it does not pull the chuck out of truth. So, when the chuck starts to unscrew, it rotates about half a turn before the grub screw does contact the groove and stops the chuck coming right off. Still very worthwhile if it stops a chuck spinning off at speed but it does not mean you can use the lathe safely to apply a cut in reverse.
                                              Andrew M
                                              #158639
                                              Ketan Swali
                                                @ketanswali79440
                                                Posted by Brian John on 24/07/2014 13:31:19:
                                                Nothing wrong at all with using the rubber feet which are supplied/fitted with baby/small lathes.
                                                Bolting of lathes to a workbence are more of an issue with bigger lathes. This is my opinion.
                                                Ketan at ARC.
                                                #158648
                                                Another JohnS
                                                  @anotherjohns
                                                  Posted by Andrew Moyes 1 on 24/07/2014 14:36:46:
                                                  Andrew – very interesting – I did not know this.
                                                  Running in reverse; I often do this with my lathes (no screwed spindles here, except for a little Unimat)
                                                  Depending on where the tool is, and what tool is in the holder, I'll run the lathe one way or the other. It makes no difference to the part being produced.
                                                  Some people have difficulty with the thought that a lathe is running in reverse, but that's their problem!
