Posted by Andy_G on 11/02/2023 09:56:01:
I built a router type machine (CNC) with a cheap, air-cooled spindle motor, and it was nowhere near rigid enough. After some re-engineering, it will cut aluminium (fairly happily) and steel (not so happy). It is still not very rigid and I'm in the process of making a new spindle along the lines of your second option.
The cause for the relative lack of rigidity can't be the linear rails? I also wanted to use them because they are widely available but I read somewhere that dovetail slides are more solid.
Thank you for all suggestions. I suppose that a stronger bench drill would work better. After all even with my Bosch drill I was able to cut a steel nut and a bolt. But I want to build one just because I find it an interesting project. It doesn't matter if in the end it might end up more expensive that a used machine. The cost will be spread over a long time.
However I'm considering also the option of buying an used milling machine in bad shape, if the cost is reasonable, and to restore it. If it is a serious machine, >600kg. That would be and equally interesting project I think. In my region there are often in the used market old Romanian milling machines. My favorite is this one, a FUS22:
It weights 800kg. But it costs 2000€. Because the seller insists in selling it together with a large rotating table, a divider head and an additional slotting head. If they are in worst shape, like what I'm looking for, they end up in the scrap yard not on Internet. And even without accessories they don't drop bellow 1500€. This days I'm also looking for a lathe and such a milling machine would consume too much from that budget.
In my ignorant view, all I need is a way to move the spindle vertically as rigid as possible. I'm happy even with locking the spindle after I set the height. To be more rigid. I don't plan to adjust it during the milling. It is not a CNC.
The rest is relatively easy. For the frame I can weld something heavy enough. Steel is cheap. I dropped the requirement to be able to move the machine alone. I can build it directly where it will stand. There is plenty of space around. It is also a well ventilated place to use MMA welding there. The electronics part like speed regulator is not a problem.
I started some talks to see how much it would cost for somebody to drop a large boulder in my yard. I heard that some high end milling machines are made from granite. I could carve the boulder outside and then move it somehow in the garage. But this is not my first choice. Or at least not yet
