DIY Epoxy Frame based CNC MILL
Viewing 3 posts - 76 through 78 (of 78 total)
  • #571373
    John McNamara
      @johnmcnamara74883
      Hi All
      When I started this project I had no idea that having got so close to a finish, Life pressures would push it into the background.
      I am also astonished that this post has been viewed about 57000 times.
      Clearly I have a debt to repay the interest received with a completed project.
      My sincere apologies for the delay.
      My workshop is now moved to a new temporary brick garage and hopefully soon I will have 3 phase power. I need the lathe to make some of the parts. I want to build a new shed later this year. But at least I can work in the temporary garage.
      At the moment I am bench testing the XYZ drive system. Will post a description soon.
      It will be interesting to see if there is any change in the alignment of the mill, having travelled on a truck about 60 kilometers crane on, crane off etc. The columns and crossmember are only bolted, as noted in the post they were to be set in epoxy then bolted to final alignment.
        That’s great news, John … I enjoyed reading about your progress.
        Jayne
          @jayne
          Hi John,
          This is an amazing project. I am very impressed with the precision you have been able to achieve so far. Looking forward to more updates and eventually seeing a video of the finished machine in action. Keep up the great work.
          Jayne
