Hi Toby,
There are two main ways likely to be of interest to you. The first is direct dividing, where the dividing plate is mounted directly on the same shaft as the job. This means that the dividing plate must be a multiple of the number of teeth you want on the gear. For example a 48 hole plate could be used to divide by any whole number divisor of 48, eg 24 teeth, 16 teeth, 12 teeth, and so on. You divide the number of teeth you want into the number of holes in the plate, and the answer is how many spaces between the holes you step over for each division.
The more versatile method is when you have a reduction between the dividing plate and the shaft with the job on it. This is usually a worm drive but may also be a gear train, simple or compound. In either case the effect is as if you have a division plate with many more holes in it. For instance, with a common 40 to 1 worm reduction, you have effectively multiplied the number of holes in the plate by 40. This mean you can do many more different divisions with a relatively small set of plates. Taking our 48 hole plate as an example, we now effectively have 48 times 40 (= 1920) divisions available for one full turn of the job, and can divide it into any whole number that divides into 1920. Now we can easily see that ten is such a number, so what do we do if we want to put ten divisions around the job? Each division will require us to move the detent by 1920 divided by ten spaces round the plate. That is 192 spaces, which comes to a nice easy 4 turns of the detent shaft for each division. (192 = 48 times 4) So we would be using the same hole on the division plate each time, and just making sure we do turn four turns each time.
Not all numbers are so easy. Suppose it was 12 we wanted. 1920 divided by 12 gives us 160 spaces for each division. A full turn is 48 spaces, so each division will be three full turns, which comes to 144, plus 16 more to make the full 160. So we want to turn the detent around three full turns, then put it in the hole that is 16 spaces past where we started. To make this easier, many dividing heads have a pair of arms that can be set to help count the holes. In this case, when we are setting up, we would set the two arms to just straddle over the outside of two holes that have 16 spaces between them. Now each time we move, we start by holding one arm (the trailing one in terms of the direction we plan to go) up against the detent pin. Keeping the arm in that position, we move the detent around the three full turns, then take it a little more and drop it into the hole beside the other arm. So provided we have set the arms up correctly, we don’t have to count each hole every time. It is of course possible for things to go wrong, so I tend to make marks on the plates as I go with a black permanent marker. A bit of meths will take these off afterwards. Another good idea is to go around the job once not actually cutting, but just scribe a line with a height gauge. Once you have gone around and marked all the way, you can check it it is showing the expected number of divisions and rethink it it is not.
Rather than do the arithmetic the hard way, you can probably find tables for the worm ratio you have. This saves some time.
Finally there is also a process called differential dividing, which at the expense of more complication and arithmetic lets you do divisions that the dividing plates and worm would not otherwise manage. I am not going to write that up here, but our learned editor does have an article sitting in his queue that gives a full explanation.
regards
