Dividing head problem with angles.
Home Forums Beginners questions Dividing head problem with angles.
  • #261505
    Brian Abbott
      @brianabbott67793
      Hello all.
      I apologies if this subject has already being covered.
      I own a small vertex 6” dividing table ( HV6 I think ) and am looking for a way to be able to use the 3 supplied plates to turn the table a certain angle..
      Ie.. how many turns + holes to rotate the table say 33.5° or can I not be that exact ?
      Maths is not my strongest subject so ideally a simple solution if there is one..
      Thanks in advance.
      Brian Abbott
        @brianabbott67793
        #261514
        D Hanna
          @dhanna35823
          1 turn of crank on your Vertex = 4 deg = 240 minutes
          33.5 deg = 2010 minutes
          Turns of crank = minutes/240 = 2010/240 = 8 3/8
          3/8 =6/16
          You have a 16 hole plate
          8 complete turns of crank+ 6 spaces in 16 hole circle = 33.5 deg exactly
          Note: that will be 7 holes between sector arms on your 16 hole plate
          Hope that helps
          Edited By D Hanna on 17/10/2016 13:16:04
          #261518
            Not sure if I'm answering the question but this site (search 'HV6' has a link to this table.
            I'm too busy at the moment to think about how to calculate angles like 33.5 degrees but I'm sure it's possible provided there's actually an approximation close enough given a particular table and wheels.
            If no-one else can provide the answer I'll have a go later.
            edit: And D Hanna posted the answer while I was typing!
            Edited By SillyOldDuffer on 17/10/2016 13:13:01
            #261621
            Brian Abbott
              @brianabbott67793
              Thanks both for replying, understand now what i need to do.
              #462867
              Brian Abbott
                @brianabbott67793
                Hello all.
                Could i ask for some advice please.
                Based on the info above, I need to rotate the table 3.6 deg.
                is this 18 holes in a 20 hole plate?
                Thanks
                #462876
                Martin Connelly
                  @martinconnelly55370
                  If your table does 1 revolution for 90 handle turns then yes. One handle turn is 4 degrees, 3.6 degrees is 90% of this. Any set of holes that allow you to use 90% of them will work. 18 of 20, 27 of 30, 36 of 40. Use whatever is available to you, small numbers are less error prone, 9 of 10 being the easiest but it's an unlikely hole count in a set of dividing plates.
                  Martin C
                  #462887
                    Posted by Brian Abbott on 06/04/2020 23:14:23:
                    Yes, 18/20 x 4 = 3.6
                    #463105
                    Brian Abbott
                      @brianabbott67793
                      Thanks both.
                      #463116
                      Howard Lewis
                        @howardlewis46836
                        If you need to rotate the table by a set number of degrees, I would suggest that you do not try mixing degrees and use of division plates, for fear of confusing yourself.
                        The Division Plates and an accurate chart will make it easy to produce the number of divisions that you want, IF it is possible with the three plates supplied with the HV6.
                        Use one of two methods.
                        Either use the vernier scale on the handlewheel, and work in degrees;
                        OR
                        Divide the required number of degrees into 360. That will tell you how many divisions are required. Then use the Division Plates to produce that number of divisions (Angular spacing )
                        I made up an EXCEL spreadsheet which tells me if that number of divisions is possible with the Division Plates for the HV6. When an extra number of divisions is needed, the required number is added to the spreadsheet, and hopefully a set number of Turns and a whole number of Holes results. If this does not happen, then that number of divisions is not possible with any of the three plates supplied.
                        One day I will get around to making at least one extra plate to increase the number of divisions possible.The road to hell is paved with good intentions!
                        Recently I needed a whole number of turns and 10.04 holes for a job. I decided that when the error had been reduced by a factor 90, I could live with the discrepancy!
                        ONE WORD OF WARNING
                        If you have a fairly old HV6, the supplied chart contains errors, and omissions. I found 8, hence the spreadsheet. I wasted a week trying to produce a 13T gear, but kept getting 12 thin teeth and one fat one. For a while it seemed that I could not count. Eventually, I made up the spreadsheet, and the errors came to light.
                        Needless to say, one of the errors was for the 13 divisions that I wanted!
                        H T H
                        Edited By Howard Lewis on 07/04/2020 21:48:10
                        #463567
                        Brian Abbott
                          @brianabbott67793
                          Hello Howard, thanks for the reply and my apologies for the delay it coming back to you.
                          I have downloaded a copy of your table now and all seems to be working out ok ( on the second attempt )
                          I can see a world or ward on the horizon i think.
                          Thanks again,
                          #463588
                          Howard Lewis
                            @howardlewis46836
                            Brian,
                            Am glad that you have now got things sorted out. Another window opening onto the world of model engineering!
                            Keep mat it!
