Dividing
Dividing
  • #158379
    D John Maycock
      @djohnmaycock87851
      Hi Everybody, I would be grateful if anybody could provide me with the method by which a Circle can be divided into equal divisions, 125 in this case using TurboCad 15, thanking you in anticipation. Regards John Maycock
      D John Maycock
        @djohnmaycock87851
        Dividing using TurboCad 15
        #158382
        Roger Vane
          @rogervane67137
          Hi John
          Firstly draw the circle that you wish to divide (including the centre point) and then identify a position on the circle itself with, say, a cross.
          Click on that cross and then activate 'radial copy'.
          Follow the instructions at the bottom LH corner of the screen – firstly, identify the centre of the circle and then the system will ask you to "define the angle step" – enter the number of divisions, 125 in your case, in the box "steps". Hit 'enter' and the job's done.
          Hope this helps you.
          Regards, Roger
          #158385
          Gary Wooding
            @garywooding25363
            Another method.
            First draw your circle, then choose the Polygon tool, tab to enter the number of sides (125) then choose the centre of the polygon as the centre of the circle and and a point on the circumference as the radius. Then draw lines from the centre of the circle to the points of the polygon.
            Done.
            #158508
            Roger Vane
              @rogervane67137
              Hi Gary
              Unless I've misunderstood your method, it sounds as if you are going to draw 125 individual lines. Think that you would find it far, far quicker to draw just one line and then use 'radial copy' to 'draw' all 125 – using 125 as the number of sets which will include your initial line.
              Both methods will work, but radial copy is far less laborious for larger numbers.
              Regards, Roger
              #158543
              Gary Wooding
                @garywooding25363
                Hi Roger,
                You are quite right. The suggestion was made only to illustrate that there is more than one way of drawing things in Tcad. I agree that the polygon method is tedious for large numbers, but its a different story for small numbers.
                #158594
                Bazyle
                  @bazyle
                  Just for the benefit of those using Draftsight it doesn't seem to have a radial copy but has Modify>Pattern then select the circle pattern.
                  I seem to remember making clock faces and machine dials easily with a freebe TCad running on a 286 back in 1999 that was way better / faster than current freebies running on gigawhatsits PCs. Such is progress.
                  #159099
                  D John Maycock
                    @djohnmaycock87851
                    Hi All
                    Thank you all for the information supplied, job done.
