Posted by norm norton on 13/04/2021 10:09:48:
Thank you all for joining the chat. But I still cannot see why, when they build a big Naval ship, the plates (panels?) all appear indented at launch.
are we thinking that the Naval ships are made with much thinner plates, to make a lighter and faster ship, and try as they might they cannot make them neatly curved all over, and have to resort to seven tonnes of epoxy filler?
So why can't thin steel panels be rolled to a correct curve, and welded to the curved bulkheads and ribs, so that it all looks neat? There is something we are not understanding, and that was the whole point of my first question.
Since big guns were rendered obsolete by aerial bombs, torpedoes and guided missiles, warships have all but abandoned armour in favour of high-speed, manoeuvrability, and automatic defences based on electronic counter-measures, anti-missile-missiles and chain guns etc. And as an anti-ship guided missile has considerably more punch than the largest 18" shells ever fired in anger, it's not unreasonable to hope a powerful missile might pass clean through the ship without exploding, which favours light-weight construction.
Warship hulls and superstructure are as light as possible consistent with remaining seaworthy and shaped to reduce radar reflections without regard to neatness. The hull is only faired as necessary to improve performance, and looking neat is well down the list of requirements.
If the indentations mattered, they could be fixed . A Type 26 Frigate costs about £10Bn so spending a few hundred million more on the hull isn't a problem. I suspect the indents either have no effect on performance, or there's a mildly positive benefit such as a reduced radar or acoustic signature, or maybe even a go-faster improvement as provided by the dimples on a golf-ball.
The cause is simple; distortion due to welding a thin plate to a frame. Merchant ships also have indented hull plating, but it's less obvious because cargo carriers are strongly built of thicker plate. Again, indents could be fixed if they caused a problem such as poor fuel economy, but I suspect they simply don't matter. It just looks untidy, and is only worth hiding on passenger ships.
Passenger ships have a long history of cosmetic engineering designed to attract customers. Classic liners built with four funnels rarely needed more than two or three. Four funnels created the impression of speed and power by imitating fast warships, even though the commercial vessel sailed at profitable speeds and, unlike a warship, was as comfortable inside as a good hotel.
