Distance of air compressor to workshop?
Home Forums General Questions Distance of air compressor to workshop?
  • #604823
    John Doe 2
      @johndoe2
      I might want to site a compressor in an outhouse, about 20m from what will be the workshop, and I would bury the air pipe across the lawn.
      The compressor would only be used for occasional use of a 3/8" drive impact wrench, maybe a die grinder, inflating tyres etc, but nothing needing huge CFMs or pressures.
      Would there be any problem with such a long run of air pipe ? I could research this, but I might get a quicker answer from you guys.
      Also, any guidance on the pipe material – plastic would last longer buried in the ground.
      Thanks.
      Edited By John Doe 2 on 07/07/2022 16:58:30
      John Doe 2
        @johndoe2
        #604826
        Speedy Builder5
          @speedybuilder5
          Can't see a problem. I have a long rubber reinforced hose about 3/8" internal diameter – probably 15m . No problem for small spray gun, tyre inflation, etc.
          I would advise flex plastic airline pipe inside flexible plastic conduit. No need to sink it really deep in the lawn. To make the "trench", sink a spade into the lawn in line with the tube, wobble spade back and forth to make the trench and sink it about 4" deep, perhaps a 18" deep when crossing flower bed.
          #604831
          Dave Halford
            @davehalford22513
            Having a buried pipe might give you condensation problems due to the cool run.
            !0mm minimum internal diameter pipe
            #604832
            Pete.
              @pete-2
              Wrap some insulation around an air hose then put it in some drain pipe before putting in the ground.
              #604833
              HOWARDT
                @howardt
                Run 22mm aluminium pneumatic pipe with a fall to one end with a drain fitting. Bury the pipe deep enough not to freeze in winter and be hit by garden implement.
                #604838
                Clive Foster
                  @clivefoster55965
                  If only for occasional use would it be too much trouble to simply get a wind up reel of airline to run out when needed. I bought a 20 m, 1/4" nominal bore, one with connectors both ends from LiDL fot £ not very much some years back. I'd probably put connectors on the outside walls ov both outhouse an workshop. With suitable weather protection covers.
                  Maybe consider an auto retract one. Unfortunately most of the less expensive ones are too short but this one from OnBuy (whoo they!)
                  https://www.onbuy.com/gb/65ft-20m-retractable-auto-rewind-air-line-hose-reel-compressor-wall~c10574~p29835393/?exta=gshp&stat=eyJpcCI6IjUwLjU5MDAiLCJkcCI6MCwibGlkIjo0MDk1OTI3NCwicyI6MzcsInQiOjE2NTcxMDIyMjksImJtYyI6IjEuNSJ9&lid=40959274&exta=gshp&gclid=CjwKCAjwiJqWBhBdEiwAtESPaPyntR3DCEP7sp-WijWPu1yk0JyckKET_jWQvVG1XcUYW2Wf2OafXhoCFx4QAvD_BwE
                  gives you 20 m of 3/8" bore for just over £50. Which is remarkable value, usual suspects are £100 (ish) or more.
                  Making a totally reliable job of burying air hose so there is no chance of condensation and other water issues is rather more effort than it might seem. So-so and usually OK isn't too hard but if I'm going to that trouble I want always works with no moisture.
                  Edited By Clive Foster on 07/07/2022 18:14:33
                  #604839
                  jimmy b
                    @jimmyb
                    I just have quick connect fitting on the outside wall of my shed for outside use (blowing up tyres etc).
                    Condensation would be a worry for something buried.
                    Jim
                    #604844
                    Maurice Taylor
                      @mauricetaylor82093
                      Hi, I would try 25mm blue water pipe ,this is rated at 12.5 bar,it’s also cheap.
                      When using air tools ,you need the largest diameter pipe possible to supply them.
                      Maurice
                      #604855
                      noel shelley
                        @noelshelley55608
                        Minimum dia 1/2" with a fall to a drain, even for a 3/8" air gun. Good Luck. Noel.
                        #604857
                        Howard Lewis
                          @howardlewis46836
                          +1 for pipe that will, not corrode. If blue water pipe can withstand at least 16 bar (Normal operating pressure x 2 ) pipe of at least 1/2" bore I would think that it should, be fine.
                          There will be a pressure drop over such a distance, so make the pipe larger bore than usual. And there will be condensation.,
                          Also at the take off point ideally configure it with a TEE, after a vertical pipe, with an elbow so that feed is from the side, the take off is on the top, and with a drain on the downward leg of the TEE.
                          #604873
                          Robert Atkinson 2
                            @robertatkinson2
                            Consider a "local" air receiver in the workshop if using smaller pipe. I doesn't have to be too big. As well as poviding the initial burst of air needed to get tools etc up to speed it will help collect any water in the line.
                            in aircraft maintence hangares you will often see airline "pigs" small receivers (often made of large diameter pipe) with one inlet and several outlets. Even if only using one outlet they make big difference to "windy" tool performance.
                            Robert G8RPI.
                            #604881
                            Simon Williams 3
                              @simonwilliams3
                              Others have already said it, but I'll add my two pennorth.
                              A rattle gun only gives its rated impact torque if it's adjacent to the air source (for which read receiver) AND connected by an oversize tail, not including a quick release fitting (PCL fitting, Schrader fitting etc). It depends what you want to rattle, but I guarantee you'll be disappointed by trying to run one on the end of a flexible pipe 20 metres long, unless it's way way oversized. Maurice's 25 mm blue pipe is a step in the right direction but I would double it to 50 mm or more if I could get it. The connecting pipe then becomes a significant energy store in its own right.
                              Robert's local air receiver suggestion is useful, but you'll need enough air stored you don't rely on the underground pipe to bring you more to achieve whatever you're giving a headache to with the rattle gun. With both air receivers charged to full pressure, the two ends of the underground connecting pipe are initially at the same pressure, so no flow takes place, It is only when the local receiver pressure has dropped significantly that air flow to refill the receiver takes place, by which time the impact wrench is a shadow of its former self.
                              Energy transfer by compressed air is inefficient.
                              #604884
                              Pete.
                                @pete-2
                                When I answered before I just thought of a simple solution that was what you asked, but really a small compressor on wheels isn't a difficult thing to move about, maybe consider storing it in your outhouse and wheeling it across the garden when you need it?
                                #604885
                                Hopper
                                  @hopper
                                  Or put your compressor against the outside wall of your workshop and build a small lean-to over it. Close to hand to switch on and off and drain the receiver but the noise is outside.
                                  #604887
                                  Steviegtr
                                    @steviegtr
                                    There is no distance. Any distance is ok. It could be half a mile away. Air . Water & hydraulic. No matter it matters not.
                                    Steve.
                                    #604894
                                    Jon Lawes
                                      @jonlawes51698
                                      I'm only an amateur, but I don't see a problem with distance or even the condensation as long as you use a moisture trap and non-corroding pipework. In my opinion the advice of a small local receiver is a good idea, however I would probably have an additional moisture trap between it and the external pipe.
                                      The regulator on my compressor tank is set almost to maximum, with smaller regulators at each spur. As a result the long length of large bore pipework between my tank and outlets is a bit of extra capacity too…. 😀
                                      #604895
                                      Paul Lousick
                                        @paullousick59116
                                        The hose to my spray gun is about 20 metres and no problem.
                                        I would use gal steel or copper tube if buried underground. Condensation is an advantage as long as there is a fall to a water trap and you would be getting drier air at the end. (moisture in the air is a problem when spray painting)
                                        #604910
                                        not done it yet
                                          @notdoneityet
                                          Pipe size and length of runnis not an insurmountable problem requiring a lot of discussion. There are plenty of recommendations for minimum diameters on the net.
                                          HERE’S ONE
                                          It would have actually have been quicker to research before posting on here! Obviously larger is better, but 2” is way OTT if the compressor is only 4cfm.
                                          #604917
                                          noel shelley
                                            @noelshelley55608
                                            A few observations on replies given ! Any air tool will require a large volume of air to work effectivly, tyre inflation and paint spray guns are not even in the same ball park. Plastic or rubber will often be eaten by rodents, Aluminium if unprotected may quickly corrode depending on soil conditions. There are only 2 types of pipe I would consider, galvanized steel, or copper for subsurface use, and no smaller than 1/2" dia. ! Noel.
                                            #604922
                                            John Doe 2
                                              @johndoe2
                                              Many thanks for all the replies and observations.
                                              The remote siting is to avoid noise nuisance – for my neighbours as well as me. Putting the compressor on the outside wall of the workshop will be close to my neighbour, and even in a cabinet will cause a noise nuisance.
                                              I would prefer a fixed installation if possible, rather than wheeling out a compressor or an airline reel every time I need a quick blast of air, or to inflate a tyre. It might be raining, and I want to avoid having to trudge across a wet lawn. My thinking would be to have the electrical supply to the compressor switched from the workshop, so I just walk in to the workshop via the internal door, switch on the lights and the compressor and I am ready to go.
                                              I had not thought about condensation.
                                              I could of course use battery tools instead, but they can be very expensive and it would be nice to be able to have a blow nozzle and a tyre inflator, so an air system seemed like a better option, but perhaps not.
                                              Anyway, thank you all for your time. Food for thought.
                                              #604943
                                              Hopper
                                                @hopper
                                                I wouldnt let worries about condensation etc stop you. It'll blow through, and you can always put a water trap at the workshop end if you want peace of mind. If noise is a factor, you don't have much other choice really. A lot can be done by putting some kind of silencer box on the air intake of the compressor. Kind of like a muffler in reverse. Anything with a bit of volume and baffles etc in it will help. But you still get some noise.
                                                #604946
                                                HOWARDT
                                                  @howardt
                                                  Be careful and use a compressed air specified pipe. Clough42 had an incident on a recent video where a plastic fitting went bang. Wether pro or hobby use incorrect fitting has the same end result.
                                                  #605037
                                                  David George 1
                                                    @davidgeorge1
                                                    Hi I don't know what compressor you have but I have installed a few systems whilst at work. One thing you should think off is if the pipe is buried can it get damaged by gardening etc. If you use a larger diamiter pipe it becomes part of the storage volume and may smooth out running on and off compressor time. You will have to take into account condensation water preferably both at the compressor and at the delivery point in the workshop. You can fit a relay to the start of the compressor but when you stop the compressor you may have to fit an auto drain valve to empty condensate from pipe and another drain the tank condensate. Make sure you have some sort of pressure gauge in the workshop to monitor what is happening and you will have to have a water trap with drain or auto drain into input to the workshop. I have fitted both iron pipe and plastic systems but prefer iron threaded pipe best and the galvanizing lasts a long time evenwhen buried.
                                                    David
                                                    #605040
                                                    pgk pgk
                                                      @pgkpgk17461
                                                      Local agri engineering has a compressor in a small shed some 20 to 30 metres from the workshop, No idea what piping comes from there but within the workshops it's 15mm copper at least another 20m with takeoff points.
