Just read the article on making display cases in the latest Model Engineer which seems a very usefull and practical method. The article prompts me to describe my mate Barrie's evolution of case making for his models for those who like glass as a material.
Initial attempts used Brass angle silver soldered together at the corners and the glazed with what he always described as 20 pennyweight glass. Picture glass to the rest of us (I guess around 2mm). The main difficulty was setting and holding the brass angle correctly in order to solder the joints. The finished result was acceptable but prone to tarnishing and plain brass angle actually looks a little thin. If you see museum cases they use a much heavier moulded section.
The next bright idea was hardwood routed to form an right angled bead ebonised and joined at the corners with fancy brass angle plates screwed in place with small brass woodscrews. Well this looked quite nice on a couple of skeleton clocks but the making of the scroll style corner angles in brass was quite time consuming. Glazing was as before using silicone sealant to attach the glass.
Realising how good a bond was created between the glass and the wooden corner beading lead to the final iteration. The corner brackets were done away with and each glass side was fitted with a surrounding edging of hardwood beading with the corners suitably mitred on facing sides and buttted on hidden aspects. The assembly was achieved essentially using the glass to bead bond as the structural strength with no need to rely on the corner joint at all. Much easier to assemble and quite light and strong. The final cases looked really good too.
regards Martin
