Thanks for all the help to date. This weekend the lathe was moved to its final position and the milling machine was assembled on the bench
Now I have hit a real snag.
The lathe came with a Nu T-link belt and a cone pulley (2″, 3″, 4″ and 5″ pulleys). The grub screw in the cone pulley turned to cheese and I do not know what grub screw to buy to replace it. I only have metric bolts and I am sure this is imperial. I bought a new drive pulley with an adaptor for the motor spindle and a new V belt but I need to make a tensioner to take up the slack before I can use it. So the quickest way to get up and running is to get the old cone and belt working.
1. How do I find out the diameter and pitch of the missing grub screw? Where would I buy a replacement from once this was established?
Mill. A secondhand Chester Champion. I had already bought a collet chuck and end mill & slot mill set for the lathe and the 3MT fitting fits the Champion. But the draw bar is different (I would have had to make one to use in the lathe anyway). The one in the mill is 11mm dia and fits the chuck that came with the mill. The collet chuck needs M8 x 1.25 pitch. As stated above I have no lathe (yet) to turn a new draw bar (and I would need to turn a metric thread on an imperial lathe with no 127t change wheel, which for a newbie like me is a daunting prospect!). Basically I need a draw bar that is M11 dia at the top to fit the mill but then M8 x 1.25 at the bottom (for 42mm worth of thread).
2. Quickest fix (bodge) for this could be to buy a length of threaded M8 x 1.25 bar and cut to the same length as the original draw bar. Two nuts at the top to lock a washer to mirror the original. I could weld the nuts together for extra strength. Does this sound a dumb idea?
Ahh, the journey of the newbie on the road to engineeringdom is strewn with stumbles so please bear with me. I though I was close to getting started but I am once again so far away
