Well Said, Peter, I support your comments whole-heartedly.
I have made a couple of long posts to this thread, in an attempt to try and help – some of my comments were made to help people to avoid paying out unnecessarily for some of the rip-offs that have (are) happening in this business.
Easily the biggest con is to be asked to pay extra for ‘digital’ equipment, notably LNBs. I am still using two expensive low-noise LNBs which were bought some years ago in the days of analogue satellite systems – both are used (successfully) in digital systems now. The fact is that the receiver paths are still the same – what is different is the signal encoding, which IS now digital, so a different ‘set-top box’ (decoder) is needed, but the crooks try to apply ‘Digital’ to everything to try and can more money out of the unknowing customer. I can only recommend anyone wanting to fit a modern system to use the Internet as much as possible, (even OT threads like this!) to try and understand what is needed, or try and find an expert for advice (not the clowns who sell them in the highstreet shop)
One comment I would make, and I will admit I could be wrong on this because I do not live in the UK, but I believe that in some cases, it is necessary to fit new terrestrial antennas for digital reception in some areas, due to change of transmitting site and signal levels, as Peter notes, but even this may not always be necessary – simple re-alignment of the antenna may work. I am sure many people can remember the days of messing about with old bits of coat hanger and ‘rabbits-ears’ to get a picture – often a good one. (but its no good for digital work!) Peter is right – don’t believe everything the salesman tells you.
I also, like Peter, am no longer in this business, but I worked for many years in satellite related communications, starting in 1967 (yes, so long ago), and have worked on design, installation and commissioning of several Intelsat and Eutelsat geostationary satellite stations (originally over 30 metres diameter), and more recently in active satellite tracking stations. Bit different from domestic TV, but the principles are the same.
It strikes me that this thread is attracting a lot of business – despite the moderator trying to delete it early on – maybe it shows just how widespread the interests of a model engineer can be
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Someone suggested a thread for general (not ME related?) chat – has the moderator an opinion (to try and get people back on his side)?
spelling errors corrected.
Edited By wotsit on 21/08/2011 12:44:07
