digital tv switchover
Home Forums General Questions digital tv switchover
Viewing 25 posts - 26 through 50 (of 73 total)
  • #73585
    ady
      @ady
      Rumour has it that the power is turned down at weekends to reduce the
      chance of faults, so that staff don’t get called out. Certainly lose
      channels at weekends.
      It’s pretty amazing what you can learn in here.
      ChrisH
        @chrish
        Thanks to all who gave advice on how to align a sat dish – I have saved the information elsewhere before all of it gets binned again!!
        Chris
        #73588
        David Clark 13
          @davidclark13
          Hi There
          I get good broadband from BT and crap from Sky.
          I only keep both in case one of them goes down so I can continue with getting the magazines out with the other.
          regards David
          #73595
          Keith Wardill 1
            @keithwardill1
            Seeing the comments to the Moderators deletion of the original postings on this thread, perhaps it is time to define some rules as to what will result in moderation action, and the consequences.
            I would suggest (as a start) that the only reasons for deletion should be personal abuse, porn content and obvious spam – what do you think?
            I support the idea of OT material because it is clear that it is welcomed by many people, and there is always the possibility that further interest will be generated by OT ideas and information.
            #73609
            Martin W
              @martinw
              Hi
              Perhaps a section for ‘Non Engineering’ topics could be opened, that way quite a lot of useful bits n bobs could be posted without too much fear causing offence.
              Just an idea.
              Cheers
              Martin
              #73614
              David Southwell ARPS
                @davidsouthwellarps
                Posted by Martin W on 20/08/2011 01:07:32:
                Hi
                Just an idea.
                Cheers
                Martin
                DAVID: Anyone who takes offence to a posting in which the the language temperate tells us more about their own limitations. IMHO such people are best left to stew in thir own juice or, should they act out, the appropriate remedy is suspension which increases in duration according to the frequency of the conduct. Beware of the few who claim offense as part of a concious or unconcious process intended to manipulate the environment to suit their own limitations!
                #73615
                David Clark 13
                  @davidclark13
                  Hi There
                  This site has no proper system for suspension.
                  We can make a member bozo which means they can’t be seen but thios just leaves holes in the posts.
                  Not a good idea.
                  regards David
                  #73617
                  Steve Garnett
                    @stevegarnett62550
                    Just an idea.
                    That works, but not without rules. After running a forum that has one of these for the last 12+ years, I think I’ve discovered what most of them are – well, enough to forestall most of the issues that arise, anyway.
                    First, you have to understand what the problem is (just like engineering, really). If a forum has a community of users based on a common issue/hobby/whatever, the chances are that their attitudes to this will share at least some common ground. It’s important to understand though, that this doesn’t necessarily extend to any other subject at all. And that’s where all the trouble starts when it comes to an OT forum. So the rules have to reflect this. And as a result, we’ve had absolutely to ban any threads about religion, politics and now, believe it or not, global warming! All of these topics have caused major fallings-out of people who otherwise get on quite well. And none of the topics has anything in the slightest to do with what the forum’s about.
                    Typically, a post like David Southwell’s above is likely to incite at least a little ill-feeling, even though it’s not aimed at anybody in particular, and I would like to think that once he’s considered it in that light, he might want to withdraw or edit it. Thing is, he can’t do this on his own after a very few minutes – he needs a moderator to do it. And that’s wrong. We’ve found that allowing people to edit and even withdraw their own posts after the fact has actually saved a lot of moderation and also quite a bit of ill-feeling – people often write things in haste that they wish upon even quite short reflection that they could withdraw, and here they simply can’t. As a result of letting people edit their own posts, the place runs a lot more smoothly, and I hardly have to intervene at all.
                    Bottom line – you have to trust people. Most people behave sensibly most of the time, and aren’t anywhere near as devious and manipulative as David thinks they might be – especially when they feel as though they are slightly more in control of the environment they’re in.
                    I’m not going to provide a complete set of forum rules (although we have them), but there are a couple which sum up most of this:
                    1. You should post in a way that is respectful towards other users.
                    Abusing users in any way will not be tolerated and will lead
                    to a warning.
                    2. We will not tolerate any harassment based on sex, race, color, creed,
                    country, religion, age, sexual orientation, class, or political opinion.
                    No. 2 could lead people to a complete ban, but I’ve not had to do that yet. We do, though, make it a requirement for forum membership that people have read the rules, and tick a box stating that they agree to abide by them.
                    But, if you ignore basic human nature, it’s going to come back and bite you – quite a lot.
                    Just like it does here….
                    Edited By Steve Garnett on 20/08/2011 10:57:52
                    #73618
                    Pat
                      @pat
                      Hi Chris and others
                      Here is a simple way to set up a dish using two sheets of paper.
                      1. Go to http://www.dishpointer.com/ enter your location Blogtown, Blogshire, UK and this will show your district on a map. It opens with a US location!
                      2. Use the map to locate the dwelling on which the dish is to be mounted.
                      3. Select the Astra 2 satellite ( The other satellites have different services so make sure you select the correct one as the angles are very different!)
                      4. Check the box on the map to show obstructions.
                      5. Use the obstruction point to pick the best location on your building or garden for the dish and increase map scale to maximum magnification. This is also an indication of how far up the wall you need to mount the dish. This is simple trigonometry but the method described below is so simple and is probably quicker.
                      6. Check that you can achieve sufficient height to clear the obstruction. Move the marker corresponding to the dish around the property and select the best location. Now for the elevation check you do this by measuring along one edge of a piece of paper the number of units from a square (90 degree) corner. Mark this edge HORIZONTAL Now measure from the same corner the height of the obstruction using the SAME scale! Now fold the paper along the line joining the two points measured earlier on adjacent edges. This is the elevation for the dish above the horizontal.
                      7. From the printed map fold along the line of the surface from which the dish will be mounted. Then fold along the line to the satellite. This is the angle of or the dish when mounted on the wall. Just make sure you do not turn the paper over!
                      8. From the point on the building on which the dish is to be mounted use the Second piece of paper to show the direction of the satellite as an angle from your selected mounting surface. Note this avoids any problems with a compass pointing at local metal work etc. Then use the first piece of paper to check there is a clear view of the sky – no buildings – trees or other objects by sighting along the paper. Use the second piece of paper to check and re check that the view of the sky at the elevation angles given by the two bits of paper is clear – then – and only then mount the disk brackets. Where obstructions are found the at the angles required for free sky view the dish position selected is too low. It is possible to use the elevation angle to calculate the height above ground level but I have not found this necessary in practice as a quick check by sighting is so easily done from the ground and ladder as necessary.
                      9. Tweek the mounting adjustments on the dish to get the angles for both elevation and bearing from the mounting surface. Nip the adjusting screws and chek the signal strength monitor on the receiver set up page for the Astra 2 satellite (There are various letter suffixes which indicate which transponder you are tuned to be it Freeview or Sky this only affects the tuning range of the TV or set top box not the dish position. If the signal quality is not sufficient then move the dish on its adjustments but check first that it is properly aligned to the bits of paper.
                      10. If the paper angles have been adhered to as well as plotted accurately then no tweeking should be necessary. I find this method is quicker than using the meter compass and can save a lot of debate on positioning in sensitive locations!
                      Just make sure the dish is mounted where it will not be disturbed.
                      Also for most LNB the leads should come out of the bottom for the correct polarisation and the fine tweeking of the angle is done using the signal strength meter either in the TV or STB or a separate meter if available.
                      Regards – Pat
                      Edited By Pat on 20/08/2011 11:09:58
                      #73621
                      Gordon W
                        @gordonw
                        Thanks for all that Pat,pity I’ve just come in after fitting my new dish, oh well. It’s for broadband, and suppliers have forgotten the paper work, so don’t know yet which sat. to point at. So will go for a pint. My second point, about posting in forums. I am new to all this, I usually write as if i’m talking to somebody in the pub, this can cause problems, because who knows if I’m joking for instance. But as a Yorky living in Scotland do have to be very careful what I say
                        #73622
                        Richard Parsons
                          @richardparsons61721
                          Pat Thanks I live in Hungary I have found your link most useful. Al I need now is to find which satellite the Beeb/ITN use and thei frequencies Then I will need get hold of the sheet metal.etc I need for a 2 Meter dish.
                          Oh by the way the Variation in Hungary is Zero degrees
                          I am glad to hear that Beckley is closing I used to be able to see it a few miles away from where I lived but could never get more a light sizzle from it. They never found out why, but i did!
                          regards
                          Dick
                          Edited By Richard Parsons on 20/08/2011 15:07:00
                          #73624
                          Pat
                            @pat
                            Hi Dick
                            If you are going to make your own dish. An easy method is to use a large block of high density foam plastic that is friable.  i.e breaks into crumbs when rubbed. Make a spade cutter out of a bit of sheet material to the correct parabolic shape. Plunge the cutter into the foam with care and a light action as the cutter is large and the cutting edge less than rigid! I have made 1 meter diameter dishes this way but 2 meter may be too big. Lay up horizontal tinned copper wires at 5mm intervals and press down into the foam and secure. Leave all wires 100mm too long to permit soldering to the edging tube. Bend and solder cross wires to complete the mesh and bend a hoop of copper tube to make a neat edge when soldered in place.
                            Remove all traces of the foam by what ever method appeals. Result is a dish with minimal visual impact good performance (provided you have kept to the profile) and low windage. The windage is important as the angle subtended to the satellite is very small which means that wind rocking the dish can become an issue particularly in exposed situations.
                            A previous contributor has given a good link to a site that shows how big a dish is normally required for any given location / satellite.
                            Just check the price of a suitable metal sheet against the cost of a commercial dish as the sheet of metal may be very expensive by comparison. Try and use a better quality LNB if you are on the fringe of the service area.  But do check the satellite operators site for recommended dish sizes along with the stations broadcast on each of the transponders to make sure you are going to get the required entertainment!
                            For Gordon,s benefit just enter Astra in to Google to list the services provided by the transponders on Astra 2 I think 2D is correct but this is from memory so please check – however since they are all on the same satellite it only comes into play when starting up the receiver.  Note the 2D transponder is beamed at the UK.
                            Good luck – Regards – Pat
                            Edited By Pat on 20/08/2011 17:07:59
                            Edited By Pat on 20/08/2011 17:23:10
                            #73625
                            Billy Mills
                              @billymills
                              There may be one simple way of transfering the azimuth angle from an already lined up local dish to another. Just watch the shadow of the LNB from about 10.25 am GMT find the time when the shadow is on the centreline of the dish. When you have the shadow on centre set up the other dish. As the Earth rotates at 15 degrees/hour or 1 degree every 4 mins this is quite a sensitive test.The only big issue is cloud in the UK! If only we would get a bit more Sun.
                              Pat’s method is certainly one way of making a dish. Often larger dishes appear as surplus but lots of people make them out of “chickenwire” on ribs, glassfibre dishes cast on foam or wet sand or by riviting sheet segments together. The latest ultra low noise blocks allow much smaller dishes to return the same performance as the old big ones.
                              Billy.
                              #73628
                              Gordon W
                                @gordonw
                                Ha ! Pat :- this is what Catch 22 was all about . Can’t get decent internet via BT, seems my wires are to long, so stuck with sub 9K until I get the dish set up, What sat ? Not arial, I know it’s not a TV sat, must wait ’till Mon. to contact agents. Could go on line ,search the net, but can’t, catch 22.
                                #73629
                                Richard Parsons
                                  Pat Thank you for that idea. But you have to know the frequency range you are trying to receive. Long ago I used to make telescope mirrors which were figured to parabolic to within ¼ of the wavelength of the mid spectrum. Figuring the mirror closer that that was a waste of time as improvements had no effect. The light could not see it! A mate of mine was on the 935 MHz CB. Wave length a little over 3 mm His dish was almost conical in section. One also has to consider the ‘F’ number of stop of the mirror as this gives you your ‘magnification’ and light receiving power.
                                  Rgds
                                  Dick
                                  #73631
                                  Pat
                                    @pat
                                    Hi Gordon
                                    Commiserations over your poor internet speed. Think the satellite service you are signing up to is at 39.0 degrees East and for the North of Scotland 14 degrees elevation or 15.5 degrees further South.
                                    Good luck for high speeds soon. Regards – Pat
                                    #73632
                                    Pat
                                      @pat
                                      Hi Dick
                                      As far as I am aware there is little impact of frequency on the design of the dish. The diameter to depth is mainly a function of the mechanics of illuminating the horn of the LNB. This is very different from an astro telescope where the aim is to bring the wave to an actual focus. The LNB has an active area of approximately 10mm square.
                                      The frequency (low GHz) is important when the dish is perforated or formed from slats. If the holes are too big or the slats the wrong dimensions the surface ceases to act as a reflector and the dish becomes transparent. The long range radio fraternity use very high gain aerials to get extra long range communications under ideal (freak) conditions. For reliable satellite reception a few extra dB are required to cope with rain clouds (10 dB is typical) but other wise the signal is reasonably constant as there is little weather in the path from the satellite. To get a reasonable signal to noise ration the gain required is low because the aerial is looking into space and is thus not picking noise from man’s activities which involve the use of electricity.
                                      To see how all of this influences the design and construction of a 2 meter dish draw the thing out to scale and pick the way the dish gathers the beam and projects it onto the LNB as this is the best way I know of showing how the various LNB feed arrangements work. Regards – Pat
                                      #73634
                                      Gordon W
                                        @gordonw
                                        Pat ,just for interest, I,ve got the co-ordinates of “my” sat, don’t know how accurate yet, :- 170 deg. x 23.8 deg. elevation, any idea what that might be? Don’t bother, does not really matter yet. Have set the dish by boy scout type methods for now. BTW this is a serious looking bit of kit.
                                        #73635
                                        Pat
                                          @pat
                                          Hi Gordon
                                          Might be ‘7E EUTELSAT W3A’ which is at that magnetic bearing and elevation for mid Scotland.
                                          #73636
                                          John Coates
                                            @johncoates48577
                                            Anybody else in the Yorkshire/Lincolnshire area lost Film 4 after the switch over on Wednesday 17th last week?
                                            We have two digital aerials both installed by the same installer at different times. The first solely feeds our digital plasma TV. The second goes to a booster/splitter which feeds five rooms. Two rooms have TV’s (one flat screen LCD digital HD, one normal CRT with a Freeview recorder box). These last two cannot now get Film 4.
                                            Think I need to get the installer back and get him to check the aerials but just thought I’d ask if anyone else had this happen
                                            #73637
                                            Martin W
                                              @martinw
                                              Have you tried retuning the the offending receivers. Sometimes this is necessary when they have completed a switchover as channel allocations are changed. Worth a try if not already attempted.
                                              Cheers
                                              Martin
                                              #73638
                                              John Coates
                                                @johncoates48577
                                                Posted by Martin W on 20/08/2011 21:45:12:
                                                Cheers
                                                Martin
                                                Yes Martin. Re-tuned every TV or box after the changeover.
                                                #73643
                                                Keith Wardill 1
                                                  @keithwardill1
                                                  To Richard Parsons,
                                                  Sorry this posting is a bit late. I note you are thinking about getting a 2 metre antenna to try and get BBC/ITV in Hungary. I am afraid you will be wasting your time. The channels you need are carried on the ASTRA 2 series. I posted a link somewhere in this thread showing the antenna footprints for these birds. The footprint for the ASTRA 2D bird is ‘tailored’ so it generally covers only the UK and Ireland at reasonable signal strength. The signal strength in Eastern Europe is too low to be useable from 2D . (However I used to be able to get a good signal in mid Germany with and 80cm dish, even so).
                                                  Just for the laugh, I obtained a 2.4 metre antenna (in Romania) – but cannot receive a useable signal for the BBC/ITV Freeview channels using a good low-noise LNB. Maybe when I have time I will sit and calculate the gain and size of antenna needed.
                                                  However, Eurobird 1 is in the same orbital slot, and carries several other free English Language channels, and this can be received with a good signal using an 80 cm dish and standard gain Sat TV LNB. (Channels such as Horror Channel, Movies for Men, various news channels including BBC and Sky. The reason for this is that the antenna pattern is not directed at a specific area, so the signal level is higher from this bird. I can actually receive about 300+ free-to-air channels, but the vast majority are crap sales channels, soft porn, religion or ethnic channels, but we have about 10 or 12 which are ‘watchable’ in English language. Another alternative if you speak German is to look at the ASTRA 19 birds – they carry all the German terrestrial channels unscrambled.
                                                  The gain of any parabolic dish is affected by by its size relative to its frequency (the higher the frequency, the smaller the dish for a given gain), but things like surface defects become significant, and can reduce the gain such that the thing is useless. The channels we are talking about are at approximately 11 or 12 GHz, so have a very short wavelength. (I guess from your comments you are aware of the significance of this). For this reason, I don’t think it will be easy or economical to build your own dish and obtain suitable performance. The only other thing which is possible is to use an LNB with as good a noise performance as possible – but this will not compensate for not having sufficient antenna gain, and will be expensive for anything other than the bogstandard sat TV LNBs.
                                                  The following links, and the two I gave earlier in this thread, have a lot of information if you can interpret it, and may help you to see what you can get in your area.
                                                  #73654
                                                  Peter G. Shaw
                                                    @peterg-shaw75338
                                                    Please permit me to post a few somewhat sarcastic comments on the whole of the digital TV fiasco.
                                                    My area was one of the early adopters of this system, and the crass misinformation being put out was almost unbelievable, amounting almost to a confidence trick.
                                                    For a start, there is no such thing as a DIGITAL aerial – all radio transmission, and this is all it is, follow the same laws of electromagnetic radiation. Your existing aerial may well be totally satisfactory. Anyone who tries to tell you need a DIGITAL aerial is lying.
                                                    What you may need, and even then I would wait until the process is fully complete, is a different group aerial, maybe a Wideband aerial, but even that is not definite. In my area, people were being advised to buy wideband and/or so-called digital aerials, when had they simply waited their existing aerial may have proved totally satisfactory. The reason is that in the interim period, the digital channels may be spread over more than one aerial grouping in order to fit them in amongst the original analogue channels. Once the analogue channels have been shut down, then it is possible to re-arrange the digital channels. Also, as has been mentioned, the initial digital channel power is deliberately reduced to reduce interference with the analogue channels. Once these are out of the way, the digital power output is then increased. Hence, if you can manage without the new digital channels, you would be well advised to wait, and then see what is required.
                                                    For what it’s worth, I went through the gamut of rearanging my aerials (yes I had two) from a group A and a Group C/D onto a wideband, only to find that the Group A on it’s own after full transfer was totally satisfactory and hence I wasted a lot of my time. Fortunately, having a spare Wideband aerial, I did not waste any money.
                                                    Apologies for being perhaps harsh, but after seeing the downright misleading information published in my area, I feel it necessary to warn people to not rush in, and to disbelieve anything you are told – it may be wrong.
                                                    Peter G. Shaw
                                                    ps. I am not an TV man, nor am I an aerial installer, but my training as a telecomm technician has enabled me to see through these lies.
                                                     Edited to remove the glaring spelling mistakes and some bad grammar.
                                                    Edited By Peter G. Shaw on 21/08/2011 11:50:18
                                                    #73656
                                                    Ian S C
                                                      @iansc
                                                      In new Zealand we are going to change over, over a 2yr period, some will be satilite, and the rest will be terestial, for the former a dish will be required, but with the terestial transmission it is being sugested that a new aerial will be required (digital), I’d advise fellow Kiwis to try there existing gear first. Ian S C
