Posted by Andrew Johnston on 09/10/2022 10:14:35:
If by an inverter the OP means a VFD as a replacement for a converter there are a number of issues.
I'd either try and fix the existing converter or swallow hard and install proper 3-phase. I did the latter and am glad I did so. I connect up my machines and they just run, as does all the control gear. So I can get on and make parts not faff around with electrics.
I don't mean a "VFD" as I've always taken those to be a specific type of motor drive which is intended for PLC control to adjust motor speed within acceptable ranges.
I do mean a converter using the same kind of PWM to generate AC from a DC input, which in turn comes from rectifying a different AC input; my understanding was that some units which were capable of and designed for use as a convertor, rather than as a motor drive, were now available.
From what i've read thus far, there are such units out there and some forum users seem happy with them, but they're not actually designed for that use, it's just that if they're sufficiently overspecified as to not be too stressed, they cope with the use case.
I'm reticent to install 3-Phase as I know I'm likely to move house in the next 2-3 years, and would need to shell out hundreds if not thousands on top of the cost of the DNO install, because it would also see the supply point moved to a completely different (and really awkward) location on my property.
If the economic climate was a little sunnier right now, I would probably be a bit less of a miser about it and just get it installed, but whilst it's (just about) the kind of spending involved is not nothing, it's more than I've ever paid for a car, or indeed any personal purchase other than the house itself!
