Digital Issues on iPad
Home Forums Model Engineer & Workshop Digital Issues on iPad
  • #71593
      I was delighted to see that issue 179 is accessible on the iPad … all previous issues require “Flash”.
      Unfortunately my delight was short-lived: because the Zoom feature only allows access to the right hand page of each double spread [and the iPad’s gesture zoom isn’t implemented].
      If anyone can offer a workaround, or tell me what I’m doing wrong, please respond.
      Thanks
        LADmachining
          @ladmachining
          The new viewer uses flash as well.
          I have just tried looking at issue 179 using IE, for which I do not have flash installed. It just gave an error screen saying I need to install flash player.
          Maybe the lack of flash on the iPad is still causing you problems?
          #71600
            Thanks for that … there must be something really strange going on, because the iPad [which, as you know, doesn’t use Flash] opens issue 179 as a “book”.
            NeilC
              @neilc
              when you first open issue 179 on an ipad there is a box telling you “swipe your finger across the pages to browse the publication or double tap on a page to zoom in” works for me ok on iPad 1. I found that the “zoom” feature only works for the last last selected ( double tapped ) page. So if you selected / double tapped the left page only left pages will be zoomed with the zoom feature, if you had selected / double tapped the right page then only right pages will zoom. I find it works ok to swipe through to browse and then double tap on the page I want to zoom.
              #71646
                Thank you, NeilC
                Yes, it works … I knew I must be doing something daft!
                Gone Away
                  @goneaway
                  Interesting, thanks for the heads up.
                  Up to now I’ve been printing the mag to pdf on a PC and then transferring the pdf to the iPad and reading it with iBooks. I just tried this direct method and at first glance, I think I still prefer the pdf route….mostly because it will fill a vertical screen with a single (full) page which is readable (just) without zooming (you can still zoom in if you need to).
                  When I tried the direct method I either got a full page that only filled half the screen or I got part of a page when I zoomed. Admittedly though, I only tried for a few minutes so I may be missing something.
