Digital editions of Model Engineer and Model Engineers’ Workshop.
Home Forums Website Questions, Comments, and Suggestions Digital editions of Model Engineer and Model Engineers’ Workshop.
Viewing 25 posts - 101 through 125 (of 170 total)
  • #49633
    David Clark 13
      @davidclark13
      Hi There
      Please email me direct with details such as name and address.
      There are contact details on this website but to save you the effort of looking, use
      regards david
      Hugh Gilhespie
        @hughgilhespie56163
        Hi David,
        I am having problems accessing the MEW digital editions. I am a subscriber to the magazine and also to the MEW Digital Archive. Up until now I have had no problems with access to the digital editions but tonight when I tried, I got as far as the pictures of the front covers (for both the current and archived stuff) but whenever I tried to select a magazine to open I received the following:
        A licensing error does not
        permit you to View this Document
        Contact your supplier for more information
        So, as I guess you are my supplier, over to you!!
        Hugh
        #49647
        Jim Whetren
          @jimwhetren72358
          Hello David,
          I seem to be having the same problem as Hugh.
          When I try to view either current or archive issues, the viewer loads with this message:
          You are not authorised
          to view this document.
          undefined
          Any ideas as to why this has suddenly happened?
          Jim
          #49648
          David Clark 13
            @davidclark13
            Hi Jim
            I have just logged in as you (which is why you were disconected).
            I can access both digital current issues and back numbers.
            Obviously I have not checked the all.
            Have you done anything different, changed or updated your browser?
            regards David
            #49668
            Jim Whetren
              @jimwhetren72358
              Hello David,
              Thank you for taking a look at the problem. Based on your browser suggestion, I had a look at ‘Internet Options’ and allowed Pop-Ups and Cookies to no avail, but if I disabled them and Mobile Code in my security suite, I now have access to all of the content.
              This is strange as these were enabled before when everything used to work. However, I know what to do now, and must just remember to turn it all back on when I have finished.
              As you can see, it’s been keeping me awake!
              Jim
              #49670
              Hugh Gilhespie
                @hughgilhespie56163
                Hi David,
                Problem solved!! And it was entirely my fault, nowt to do with the website – the date on my computer was set to may instead of March. Heaven knows why but putting it back to the correct date has solved my problems with access to the digital editions. Now, if I actually receive my copy of Issue 162 in the post rather than having to read it online I will be a contented bunny.
                Regards, Hugh
                #50446
                Martin Rock-Evans
                  @martinrock-evans77799
                  Hi David,
                  I’m experiencing the same problems as Hugh was. Using either Internet Explorer or Google Chrome, when the pop-up that usually has the digital magazine in it appears it simply has the text:
                  I get the same message for all the back issues and these have been working in the past.
                  Many thanks, Martin
                  #50447
                  Dave Jones 1
                    @davejones1
                    Morning David,
                    Same problem here I am afraid.  Its worked fine last week, and I went to look at the back issues this morning, and up popped the same message as above.
                    Bruce Tunnicliffe
                      @brucetunnicliffe56390
                      The identical problem here…. (it seemed to occur after the planned update)
                      regards,
                      Bruce
                      #50452
                      Bruce Tunnicliffe
                        but it is working again!!
                        now what am I going to look at next…
                        Bruce
                        #50455
                        Hugh Gilhespie
                          @hughgilhespie56163
                          Hi All,
                          My problems accessing the digital issues were because my computer was set to the wrong date after a service visit from Dell to fix a different problem. When I reset the date to the correct value access was OK again.
                          Hope this helps!!
                          Hugh
                          PS – Feeling smug as have just done my first ever parting off – Glanze carbide tool from Chronos, front tool post, had to set the tool height to centre very precisely but then everything worked fine.
                          #50476
                          Dave Jones 1
                            @davejones1
                            Mine is also fixed, however it seems to have done it by itself (cheers IT guys!)
                            #50658
                            Fred Townroe
                              @fredtownroe25083
                              David,
                                   I have finally received my first two issues of the magazine ( #’s 160&161) but cannot log onto the digital archives.  I registered and used the number that Heather was kind enough to provide me, but the site still says it has no record of my subscripton.  Of course I no longer have the overwraps from the magazines with the account number on them and the E-mail receipt that I received from Express Mags has only 7 digits. I find the content excellent but need some prior issues to start the filing machine project.
                              Thanks for your help
                              #50895
                              Peter Jackman
                                @peterjackman96448
                                I am a subscriber to both M.E. and M.E.W.
                                My subscriber numbers to both these are entered in my prifile.
                                The MEW subscription is giving me access to MEW digital archives but the ME subscription does not give me access to ME digital archives.
                                Why is this. Am I doing something wrong?
                                Peter Jackman
                                #50897
                                Circlip
                                  @circlip
                                  Yes Peter, you PAID.
                                    Regards  Ian.
                                  #51360
                                  Jim Whetren
                                    @jimwhetren72358
                                    The saga continues –
                                    What’s gone wrong with the MEW digital archive? I was going to look at an early issue, but found that the archive only went back to issue 122.
                                    I may be jumping the gun if this is due to the re-scanning of the earlier issues, but if this is not so, then why have I paid £29 for a year’s access to the archive?
                                    Jim
                                    #51366
                                    Terryd
                                      @terryd72465
                                      Hi Jim,
                                      Just a thought,  are you sure that you’re looking in the correct place?  The free access ‘Digital Issues’ files only go back to issue 122, but these are not the same as the paid for subscription archives which include all MEW.
                                      Terry
                                      #51367
                                      David Clark 13
                                        @davidclark13
                                        HI Jim
                                        If you have paid, you should be able to access all issues.
                                        Have you put your subscriber number into the digital editions bit of the website.
                                        In your profile.
                                        You can phone me if you like and we can try and sort it out.
                                        regards David
                                        #51369
                                        David Clark 13
                                          @davidclark13
                                          HI Jim
                                          Have checked your account.
                                          Digital subscription is there.
                                          No problems.
                                          regards David
                                          Edited By David Clark 1 on 03/05/2010 09:42:26
                                          #51373
                                          Circlip
                                            @circlip
                                            Beware the Ides of May DC1
                                              Regards  Ian.
                                            #51374
                                            David Clark 13
                                              @davidclark13
                                              HI Circlip
                                              What does that mean?
                                              regards david
                                              #51377
                                              Jim Whetren
                                                @jimwhetren72358
                                                Terryd,David & Circlip,
                                                Terry – I should read everything before doing anything! Thank you.
                                                David – I apologise for being a pillock, thank you for your input.
                                                Ian – You are right, today is my birthday, I’m too old for this…..
                                                Thank you all again, I promise to Buck Up.
                                                Best regards,
                                                Jim
                                                #51378
                                                Circlip
                                                  @circlip
                                                  Whatcha doing NEXT weekend DC1???????????????????????????
                                                  #51381
                                                  David Clark 13
                                                    @davidclark13
                                                    Hi There
                                                    Harrogate I hope.
                                                    Friday, Saturday and Sunday.
                                                    Hope there are no woman drivers on the road Sunday.
                                                    Damn woman wrote my car off going home from Myford.
                                                    If the wife’s car gets wrecked, I have been told not to go home.
                                                    regards David
                                                    Edited By David Clark 1 on 03/05/2010 11:50:25
                                                    #51688
                                                    ColH
                                                      @colh
                                                      I may have missed something somewhere along the way but I thought at one stage the lastest edition of MEW was made available in digital editions section before it was availabe in the shops and shown on the home page.  I know a few complained about this (I can’t understand why as if you don’t want to see it early then don’t look) but I looked forward to the sneek preview of the next edition before the paper version arrives in my mail box.  Any chance of going back to the way it was?
                                                      regards Col
