By fair means and foul I now own four different Digital Calipers. They cost me £4.99, £9.99, £30 and £50. The £50 caliper was significantly reduced from the usual price as a special offer.
Only the two expensive calipers came with a calibration certificate. They both claim ±0.02mm.
I measured a precision parallel five times in each dimension. I took care to measure the dimensions at the same point on the parallel each time. The precision parallel came with a certificate claiming 100 ±0.01mm, 6 ±0.02mm and 24 ±0.005mm
The calipers and parallel were cleaned before the test. The order of testing was shuffled by rolling a dice. The temperature was 19℃.
I also recorded the zero reading before and after each set of five readings. I did not reset zero during each round of 15 measurements.
Results
Average of Five Readings (mm)
'100mm' '6mm' '24mm' Zero at end
Caliper A 99.916 6.012 24.042 -0.01
Caliper B 99.922 6.038 24.028 0.02
Caliper C 99.952 6.028 24.070 0.00
Caliper D 99.880 5.976 23.968 -0.01
Standard Deviation (mm)
Caliper A 0.086 0.008 0.051
Caliper B 0.018 0.013 0.030
Caliper C 0.019 0.013 0.031
Caliper D 0.014 0.011 0.013
I find it difficult to work out from the readings which Caliper is which. The strong implication is that, for home workshop use, expensive Digital Calipers are not good value for money.
Are you able to identify the expensive Calipers and can you rank the calipers according to which was the best deal?
Of course it's possible that I've only proved that good calipers are wasted in my clumsy paws. Even if that's true, I still conclude that my money could have been spent better. I'd be grateful though for any comments that might improve my technique.
Cheers,
Edited By SillyOldDuffer on 26/09/2016 13:36:34
