I did an experiment with my usual caliper – not Mitutoyo, it's Proops, circa 2000
Left set at 0.01 on the bench for several hours, it crept up to 0.01mm.
I then opened and closed it as fast as I could (as in literally snapping it closed). i could not get an error.
Put it on a windowsill about 5" above a heater, left it there for about two hours until it was very warm. To my surprise it read 0.10mm, quite a change!. It's back on the bench now, and in the time it's taken me to type this the display has dropped to 0.08mm.
<Interruption while one of the lads comes in and says 'have you ever heard of a band called 'Wishbone Ash'?>
It's flickering between 0.06 and 0.05mm now.
I just tested it on a 25mm test bar, and it reads 25.05mm.
My immediate conclusion is that these cheap units are highly temperature sensitive but that the error is a zero error, so that the issue is keeping them at the same temperature your zeroed them at.
P.S. it's flicking between 0.04 and 0.03 now, and doesn't feel warm anymore.
