Digital caliper connector leads?
Home Forums General Questions Digital caliper connector leads?
  • #22091
    Cornish Jack
      @cornishjack
      Cornish Jack
        @cornishjack
        G'day all
        Does anyone know if these leads are available as spares and, if so, from whom? The leads are the ones which plug into the sockets on the 'top' of most digi-calipers with four built-in connector strips.
        TIA
        Rgds
        Bill
        #90211
        Skarven
          @skarven
          Hi,
          Littlemachineshop lists two types of cable to connect "inexpensive imported DRO scales to a display unit", one with Mini-DIN and one with RJ-11. I think these "inexpensive imported DRO scales" have the same interface as the calipers.
          http://littlemachineshop.com/products/product_view.php?ProductID=3483&category=132430212
          It all depends on what you wants to connect it to smiley
          #90221
          Gray62
            @gray62
            I've tried these leads and found that the connection is somewhat intermittent as the connectors do not have any positive method of retention and are not a tight fit in the receptacle.
            In the end I dismantled the caliper and soldered direct to the PCB – not too bad a job with a steady hand, good eye and a fine soldering iron ( I only have the soldering Iron and still managed to do it LOL ).
            I would suggest using screened cable as an extra assurance against interference and bond it to the machine only.
            Also isolate the caliper from the machine as on the original types with the 1.5V battery, the metalwork of the caliper is connected to battery positive.
            Graeme
            #90222
            Cornish Jack
              @cornishjack
              Thank you Skarven and CoalBurner.
              The LMS item looks very much like what is needed but (Sod's Law!) the critical connector is the one at the top right of the photo and not clearly visible (to my rheumy old eyes!) Also problematical is that LMS are in the States,so not quite so accessible.
              Graeme – I, similarly, have the soldering iron but not only lack the other two 'ingredients' but don't have the 'what connects to what' details!! The lead I have at the moment has been savaged in two places and continuity checks are a bit inconclusive.frown
              Rgds
              Bill
              #90229
              Keith Wardill 1
                @keithwardill1
                Hi, Bill,
                This website may be some help:
                http://www.shumatech.com/support/chinese_scales.htm
                I had the same problem using these scales as part of a DRO system – Coalburner is correct when he says there is no positive location, so I soldered the connections in the end – pinouts are in the data on the website. Note that Mitutoyo scales have different connections to the commonly available 'chinese' scales, so check wht type you have.
                #90232
                Les Jones 1
                  @lesjones1
                  Hi Bill,
                  I agree with CoalBurner and wotsit regarding the reliability of these connectors. I bought some from Warco a few years ago but they no longer seem to list them. Also be aware that there are at least three different protocols used by these calipers so you neeed to be sure they are the correct type for the equipment you plan to connect them to.
                  Les.
                  #90234
                  Sub Mandrel
                    @submandrel
                    I agree with what's been said – the connectors are c**p, so I soldered my leads in place.
                    ARC do some with mini-USB connectors instead but note they are NOT USB compatible.
                    Gone Away
                      @goneaway
                      Like all the other guys, I soldered direct to the pads. It's straightforward enough if you take your time and easier if you dismantle the device.
                      I differ slightly with Coalburner in that I ground the shield at the DRO only and isolate it from the machine, which works well for me. (In any event, you certainly wouldn't want to connect it to both). In which case, you shouldn't need to isolate the caliper/scale which may be problematic.
                      Edited By Sid Herbage on 04/05/2012 22:44:20
                      #90256
                      Cornish Jack
                        @cornishjack
                        Thank you, Wotsit, LJ1, Neil and Sid.
                        Looks like the soldering route is favourite … BIG magnifier and, maybe, some 'Scottish Milk' to steady the hand!! I've managed to find a site with the pin-outs for the cheapo versions so will proceed with caution!
                        Rgds
                        Bill
                        #90268
                        Gone Away
                          @goneaway
                          Jack/Bill, tin the four pads before you start and tin the stripped ends of the leads. Hold the lead resting on and aligned with the pad with one hand and use the other to apply the soldering iron.
                          No need to apply more solder, just "sweat" them together
