BS 970 has been generally superseded by European based standards – where will it all end?
BS970 Numbering system explained
The BS970 code number is constructed as follows;
a) The first three symbols are a number code indicating the type of steel:
000 to 199 Carbon and carbon-manganese steels. The number represents the manganese content x 100
200 to 240 Free cutting steels. The second and third number indicate the sulphur content x 100
250 Silicon Manganese valve steels
300 to 499 Stainless and heat resisting steels
500 to 999 Alloy Steels
b) The fourth symbol is a letter code .
A The steel is supplied to a chemical compostion determine by analysis of the batch sample.
H The steel is supplied to a hardenability specification
M The steel is supplied to a Mechanical Property specification.
S The steel is a stainless steel
c) The fifth and sixth symbol is a number is the actual mean carbon content x 100
In addition to the above coding a condition coding may be applied. indicating the tensile strength range after heat treatment. This is used in conjunction with a limiting section designation.
So that makes it all crystal clear doesn’t it
