Dickson Tool Post . – can it be drilled ?
Home Forums Materials Dickson Tool Post . – can it be drilled ?
  • #62165
    WALLACE
      @wallace
      Hi everyone.
      I wan’t to mount a Dickson type parting off tool holder upside down so I can run the lathe backwards when parting off. I’m not sure of the make, but I iamgine it’s UK  . . (not Chinese !).
      So I need to drill and tap a new hole on the bottom to take the height adjustiong screw.
      Any ideas if they’re through hardened and impossible to drill ? !
      thanks.
      W.
      WALLACE
        @wallace
        #62168
        KWIL
          @kwil
          Has it got  a “W” engraved in the clamping slot?  Why do you want to run backwards?  You will be trying to lift the carriage.
          #62171
            Kwil, I’d be interested to know what the  “W” is for as my original one has these marks but some of the holders I have subsequently bought don’t. I assume the “W” is a try Dickson and not an imported copy.
            J
            #62172
            KWIL
              @kwil
              Correct.   Weston Engineering  Some think it is an upside down M for Myford.
              #62173
                Thanks Kwil
                Well my imported holders are hardened (needed altering to get a good fit) so I assume the proper job will be as well. You may want to read the thread about chuck jaws to see how to unharden your holder.
                J
                Edited By JasonB on 10/01/2011 19:05:47
                #62250
                WALLACE
                  @wallace
                  Hi Kwil.
                  I haven’t room on the lathe to put in a rear tool post  – so was going to try mounting it upside down instead and run it in reverse (it has a LOO taper so won’t come loose).
                  I’m assuming the geometry to aid parting off would be the same –  but will probably try it first before I mangle the holder !
                  W/
                  #62259
                  Bill Pudney
                    @billpudney37759
                    On “upside down” parting off tools.  I recently completed a QCTP set up for my Sieg C3.  Amongst the changes I included a pair of upside down toolholders.
                    Despite all the prophets of doom they work extremely well.  Where parting off used to generate considerable stress, it’s now a relarively calm procedure.
                    There are some photos in the Gallery, look for “QCTP”
                    cheers
                    Bill Pudney
                    Adelaide, Australia
                    #62274
                    Chris Trice
                      @christrice43267
                      I remember seeing a QC rear tool post for parting off on Myford’s stand at Sandown.
                      #62275
                      Chris Trice
                        @christrice43267
                        Here you go:
                        That’s assuming you have a Myford or it might be adaptable..
                        #62837
                        Tony Jeffree
                          @tonyjeffree56510
                          Posted by WALLACE on 10/01/2011 16:20:49:
                          Hi everyone.
                          thanks.
                          W.
                          What kind of spindle nose do you have? If it is screwed (e.g.,  Myford), then this is a very BAD idea. I hope I don’t need to explain why
                          Tony
                          Edited By Tony Jeffree on 20/01/2011 08:58:51
                          #62858
                          Terryd
                            @terryd72465
                            Posted by WALLACE on 11/01/2011 19:52:41:
                            Hi Kwil.
                            W/
                            Hi Tony,
                            He answered this possible problem on the posting above
                            Terry
                            #62863
                            Tony Jeffree
                              @tonyjeffree56510
                              Posted by Terryd on 20/01/2011 10:41:33:
                              Hi Kwil.
                              W/
                              Hi Tony,
                              Terry
                              Ah..ok…missed that!
                              Tony
                              #62875
                              John Coates
                                @johncoates48577
                                I bought a Dickson type QCTP from Chronos and bored it out from 7/16ths to 1/2″. We (folks on here) figured out in the endit was case hardened
                                Here’s how I did it:
                              Home Forums Materials Topics
