Well, after many years I have lashed up a tool & cutter grinder, own design using bits of worden, stent, quorn all re-arranged to suit me.
Anyway, I purchased a 4" white cup wheel (no markings at all so probably Chinese s**t) from one of the usual suspects which seems very soft. Dressing it produces ridiculous amounts of grit all over the shop. Even taking grinding cut of a couple of thou can produce more clouds.
I am trying to keep the T & C grinder in the machine shop to avoid rust. I could put it in the welding / grinding area but that is very prone to rust. Carrying it to and fro for wheel dressing is possible, but hard work.
I have been thinking about changing to a diamond / cbn wheel (Arc Euro & others do them). Obviously great for carbide tooling, but what about using them on HSS?
Seems to me it would cut out the clouds of grit when dressing problem. Anyone have any experience good or bad?
Many thanks,
Martin
