Dial gauge troubles
Dial gauge troubles
Home Forums Workshop Tools and Tooling Dial gauge troubles
  • #771597
    Roger Hart
      @rogerhart88496
      I have an old J E Baty (marked HI-TECH) gauge marked .0001″.  It was very sticky and after a good clean it sort of works OK but.
      The return to zero is a bit unreliable,  seems to be affected by how far or fast it returns when it will shift the return reading by about 5/10ths thou.
      I have some experience with small mechanisms and made sure all wheel teeth were clean and the dial needle is firmly ‘on’.
      There is some sort of friction/safety clutch on the measuring rod to gear train 1st wheel which looks to be the only source of variability.
      Any ideas?
      roy entwistle
        @royentwistle24699
        have you lubricated it? if so what with?
        #771621
        Roger Hart
          @rogerhart88496
          Yes,  with watch oil
          #771639
          bernard towers
            @bernardtowers37738
            I have rebuilt a couple of dial gauges an found they work better with no lube IMHO
            #771670
            roy entwistle
              @royentwistle24699
              wipe the oil off the pivots and plunger with a tissue and try again
              #771675
                Though it might only need a clean and a tiny drop of light oil, an old DTI could also be worn, or more likely, the innards are bent due to being bumped or dropped.   A powerful loupe might see the damage, better a microscope.  Small flaws matter to delicate instruments working in the tenths region.
                Maybe bad maintenance in the past.  Clocks are famously damaged by over oiling.   The oil attracts dust and becomes abrasive, and then gums up.   The mechanism literally grinds to a halt, and then the bearings have to be replaced.  The old ones have enough slop to upset the gears.
                How elaborate was the clean?  Clocks and watches are stripped down completely and the parts put through an elaborate sequence of agitated chemical cleaners, and inspected for damage, especially the pivots, before reassembly.  Iffy parts are replaced.   I think a tenths DTI would need a similar deep clean.
                Roger Hart
                  @rogerhart88496
                  Thanks all.  I stripped the mechanism and cleaned again.  Also removed plunger rod (which seemed OK) and found some sticky goo on it (laziness!).  Cleaned rod and rack and replaced.  No oil this time.  Seems much better,  a 1/10ths DTI does seem a bit more fussy – but worth persevering.
                  Will return to testing after the hols – family stuff calls.  Merry Christmas all.
                  #771723
                  Nigel Graham 2
                    @nigelgraham2
                    Thankyou for this thread – I have a DTI with reluctant return action so will take that advice, too!
                    #771758
                    Clive Foster
                      @clivefoster55965
                      Nigel
                      Rule one with fixing DTI is clean, clean, clean, clean again and polish the plunger rod.
                      #771782
                      roy entwistle
                        @royentwistle24699
                        I was once told by an old watchmaker  If you think about oiling it, that’s enough
                        #771801
                        Grindstone Cowboy
                          @grindstonecowboy
                          I find that the very slightly oily film left behind if you clean the parts with lighter fluid is more than enough lubrication.
                          Rob
                          #771811
                          peak4
                            @peak4
                            I’ve fettled a couple where I couldn’t work out why they were stiff initially.
                            It turned out that the rack and pinion were slightly too well engaged for want of a better way of putting it.
                            The rack, in my terminology, being the teeth cut into the plunger shaft.
                            The depth of engagement should be adjustable, but the means isn’t always obvious.
                            On one clock, it needed the crystal, hands, and clock face removing; this exposed some screws to allow the body to rotate in the case and set the clearance.
                            Bill
                            #771834
                            Mick B1
                              @mickb1
                              When I worked for Baty’s nearly 40 years ago I had a little Emco Unimat 3 and was looking for a general purpose dial gauge. The Chief Inspector prepared a 0.0005″ D4 gauge for me with a 0.300″ range of travel that gave a lot of versatility. I still use it for most purposes.
                              He advised me not to oil it.
                              The only time I’ve noticed inconsistent return to full extension, it was due to fluff collecting under the flat head of the stop screw at the top end of the rack spindle. After very simple cleaning it was returning within a tenth or so every time. Normally for checking concentricity or parallelism I advance the gauge so as to extend the return spring to about half total travel – that generally cuts out dependence on any mechanical limit in the gauge.
