descaling steel
descaling steel
Home Forums Hints And Tips for model engineers descaling steel
  • This topic has 21 replies, 15 voices, and was last updated 2 June 2014 at 00:47 by John Stevenson 1.
  • #120736
    John Stevenson 1
      @johnstevenson1
      As many may know I make a lot of special dividing plates, these are made from laser cut blanks usually out of a material called A36 which is a hot rolled steel plate that has a thick oxide layer on it.
      There is an alternative material called HRPO which stands for Hot rolled picked oiled, basically A36 but cleaned up, costs more and not every company uses it of has it in the stock you want. They like A36 because the oxide layer stops reflection and also stops any dross sticking the the top surface.
      Problem with A36 is the thick oxide coat destroys the tips on drills in a heartbeat, OK for the odd hole and if you heavily centre punch that also helps but many thousands of holes on a CNC is asking for a broken drill, especially in under 3mm sizes.
      So what's special about HRPO ? Basically it's been through a commercial picking process, so if we can replicate this it helps with laser cut frames, angle iron and anything that needs to be finished, paint sticks the HRPO better than A36.
      Picture of a plate straight from the laser cutters.
      Also in the picture is a piece of bronze and a piece of copper to see how these perform. I'll say at this point the process didn't do much for them.
      A tub was prepared out of an old plastic 5 gallon suds container by cutting the side out and a 'plate rack' cut on the laser to hold 20 plates which really only applies to me.
      The solution used is Cementone Brick and Patio cleaner which is basically a weak hydrochloric acid. Don't buy any cleaner that says GREEN on it, that's just basically soapy water.
      I mix this 1:1 with water and in my case it takes 10 litres of solution.
      I put these in the tub last night at about 7:00pm and just been out 10:30 am following day and they are all clean and de-scaled, just need a rinse and a wipe with oil.
      Even cleans the 'burnt' laser cut edge up.
      John Stevenson 1
        @johnstevenson1
        #120739
        Thor 🇳🇴
          @thor
          Thanks for a handy tip John, where I live hot rolled steel (similar to your A36?) is readily available and I use it fairly often. I suppose you use rubber gloves and eye protection when handling HCl.
          Thor
          #120741
          MadMike
            @madmike
            Remember that simply pouring the diluted acid down the drain, after use, will almost certainly p**s off your local water company. Dispose of the residue carefully.
            #120742
            John Stevenson 1
              @johnstevenson1
              Posted by MadMike on 27/05/2013 12:28:06:
              It's sold for brushing on the patio ??
              #120746
              Tony Pratt 1
                @tonypratt1
                I live in an area with the hardest water going so I would imagine putting 10 litres or so down the drain would not even be noticed by the water company, obviously 1000 litres is a bit different?
                As an aside how exactly would one 'Dispose of the residue carefully'?
                Tony
                #120747
                Thor 🇳🇴
                  @thor
                  Tony, if you add sodium carbonate gradually to the residue until it stops fizzing it should be a neutral or slightly alkaline salt solution that you can dispose of in the drain. And as you say, 10L is a small amount and when diluted poses no problem.
                  Thor
                  #120773
                  Sub Mandrel
                    @submandrel
                    They sell even stronger HCl as drain cleaner. It dilutes pretty rapidly, but best to put it down the foul sewer. The things that cause real problems are:
                    • Mis-connected dishwashers and washing machines (i/e/ connected to the surface drains that end up in local watercourses)
                    • Sump oil (or any waste engineering oil, agine expecially when ending up in surface water)
                    • cooking fats and oils (down the sink or loo ends up blocking drains or gumming up sewage works).
                    I have seen the effects of an estate with plenty of misconnections – a completely dead stream with nothing but a white layer of sewage fungus all over the streambed.
                    John Stevenson 1
                      @johnstevenson1
                      If you use it until it stops working it's no longer acid but dirty water.
                      Come one guys you are taking H&S too far.
                      #120802
                      Chris Heapy
                        @chrisheapy71135
                        What you don't wnat is it sitting in your drainage system for while, it will eat the pipes or the cement grouting holding it all together.
                        I dimly recall an electrolytic method of descaling and removing thick corrosion from iron/steel. I'll have to search for it again though. Essentially it was very effective and the article I read described how rusted items (old wagon implements I think it was) dug up from the earth could be completely descaled.
                        #120842
                        Ian S C
                          @iansc
                          The electrolitic method works ok. If you don't like strong acids, citric acid will do the job, just takes longer, Most of the scale falls to the bottom of the container, and when you are finished with the acid, you can tip it down the drain, its proberbly less dangerous than Coka- Cola (you could use that too). Ian S C
                          #121030
                          Tony Jeffree
                            @tonyjeffree56510
                            Yep, Coke works just fine, and probably Pepsi too – basically dilute phosphoric acid with added flavourings and bubbles. I wonder if this is how they make Irn Bru…? smiley
                            There are other similar (to the patio cleaner) products sold for cleaning grout and cement residue off tiles/slabs – there's one available on Amazon for £14 (£3/litre) that is 36% hydrochloric acid which would need rather more dilution before use than the Cmentone one (which looks to be 5-10% as far as I can tell):
                            http://www.amazon.co.uk/Hydrochloric-Acid-36%25-Industrial-Strength/dp/B00BQFG6NS/ref=sr_1_1?s=diy&ie=UTF8&qid=1369913685&sr=1-1&keywords=hydrochloric+acid
                            Tony
                            Edited By Tony Jeffree on 30/05/2013 12:43:10
                            #121470
                            oldvelo
                              @oldvelo
                              Hi can I point you to this site on setting up to clean with "Electrolosys"
                              http://antique-engines.com/electrol.asp
                              I use this method for ceaning up steel and cast iron parts ready for painting or Blacking.
                              Eric
                              #121471
                              Hopper
                                @hopper
                                Just have the garden hose running down the drain as you tip in the spent acid. Then leave hose running for a while afterwards to make sure acid is not sitting in your drain pipes.
                                #121481
                                John Stevenson 1
                                  @johnstevenson1
                                  Can I try and make a point ?
                                  When the acid has stopped working and won't clean any more plates it's no longer acid but dirty water.
                                  But if I had bought this stuff for the purpose it's made and sold for, I would have sloshed this on the yard and brushed it down the drain.
                                  So it's OK to use it as directed but not OK to clean rusty parts and steel plates with it ???????????
                                  Enquiring minds DON'T want to know. blush
                                  Actually glad this post has surfaced as it's just remined me. On Sunday clearing a shed out I found a set of dividing head change wheels, probably brand new but stored for years and gone rusty.
                                  So popped then in the solution, just remembered them and fished them out, wrinse under tap and this is what i have now.
                                  No messing with batteries, power supplies etc just bung it into a tank and leave for a day.
                                  Edited By John Stevenson on 29/06/2013 13:02:19
                                  #132334
                                  Cyril Bonnett
                                    @cyrilbonnett24790
                                    Vinegar works just as well, cheap stuff out of Lidls, remember not to do this in your workshop the fumes will cause other steel objects to rust,
                                    Jerry Wray
                                      @jerrywray14030
                                      Cyril provided a link to as site discussing this subject.
                                      One of the posters there mentioned muratic acid as if this is some arcane product of the alchemist's art.
                                      Muratic acid = hydrochloric acid. It's a synonym. Now hardly used. There's enough attempts to disguise the real properties of chemicals without resorting to ancient history.
                                      JerryNotts
                                      #132350
                                      jonathan heppel
                                        @jonathanheppel43280
                                        There is one caveat I can think of. Hydrochloric acid gives off highly corrosive fumes that will rust any ferrous metal they land on- particularly in damp air.
                                        General advice is to use it out of doors or at least outside the workshop, A safer alternative is phosphoric acid, either from the net or a farm shop.
                                        #132385
                                        Sub Mandrel
                                          @submandrel
                                          I've been regrouting the bathroom. I got some 'acid detergent' that contains phosphoric acid. It states that it 'removes rust stains when concentrated' at about £6 for 2 litres I fancy it could be quite effective (it's ruining my skin…) I'll try it on something.
                                          John Coates
                                            @johncoates48577
                                            Thanks for this John
                                            I'd bought some of this for de-rusting as had read about it before but have not used it yet
                                            Your tips are excellent and I'll follow them to tackle some tooling I have made but needs a de-rust before blacking e.g. a locking bar for my motorcycle tyre bead breaker, wheel spacers
                                            t'other John
                                            #153960
                                            _Paul_
                                              @_paul_
                                              Apologies for raising one of John's old threads from the dead but Toolstation have Cementone Brick & Patio Cleaner 5L on offer for £6.73 spend over a tenner and the delivery is free.
                                              Paul
                                              #154141
                                              John Stevenson 1
                                                @johnstevenson1
                                                Thanks Paul for the heads up.
                                                Popped up today and grabbed two tubs as mine is getting old and not working very well.
                                                I drilled over a 100 brackets yesterday out of 1 1/2" x 1/4" black steel strip ans they need hot blacking.
                                                The hot blacking doesn't work well on black steel because of the scale so stripping it all off gives a very professional finish.
