Many thanks JasonB & JA.
The tool is an Australian tangential HSS and is almost the only tool that I use.
For an oldie it is so easy to sharpen and set to centre height.
I know there are lots of criticisms of the S7 but for all I do it is fine.
The steel is to be a mandrel to mount a cylinder (Perseus) so that I can
face the front end.
I used an HSS tool to bore the cylinder and I could not believe the
lovely finish it left. I did run it through four times without increasing the cut
at the and. So I did not need to buy a reamer!
Am very grateful for everyone's help.
Richard.
