Denford Triac – Remove Easy Change Holder?
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Denford Triac – Remove Easy Change Holder?
  • #411166
    Mark Slatter
      @markslatter13251
      Hi all,
      I have a 1986 Triac, it has the Easy Change tool holder with "R8" written on the side. Is it possible to remove the Easy Change tool holder from the spindle or is it integral? I have removed the bolt/drawbar a few threads and given the bolt a few taps but there doesn't seem to be any movement of the tool holder. It is likely that no one has tried this since the machine was manufactured however, and it may be a touch tight!
      Any help appreciated, thanks
      Mark Slatter
        @markslatter13251
        #411171
        David Jupp
          @davidjupp51506
          This document from the Denford forum includes an illustrated parts list for Triac.
          #411176
          Mark Slatter
            @markslatter13251
            Many thanks for the link David, those diagrams clearly show a standard R8 taper which indicates the tool holder should tap loose. However the plot thickens as the Triac Series User Manual states the tool holder is "permanently attached to the spindle".
            #411179
            John Haine
              @johnhaine32865
              What I think it means is that the Easychange holder is left in the spindle and you then have chucks with a quick-release taper that clip into the holder. My Novamill has a BT30 spindle taper and an Easychange holder that fits in that – then it came with 2 ER16 collet chucks.
              In practice the Easychange holder eats too much daylight and the chucks with the proprietary clip-in taper cost ££££! So I hardly ever use the Easychange system, I got a couple of BT30/ER16 chucks off eBay, but seldom change tool by having them preset in a another chuck. If there's a drawbar it indicates the holder should be removable, sounds like it's been left in and has seized a bit.
              #411182
              David Colwill
                @davidcolwill19261
                Hi,
                I had a triac with the r8 taper and the easychange holder does come out as you suspect..
                David.
                #411183
                Mark Slatter
                  @markslatter13251
                  Hi John, you are indeed correct. I have just got back from the workshop and a firm tap with a hammer released the tool holder. I was hoping it was removable for exactly the reasons you outlined! Many thanks for the replies
                  #411184
                  Mark Slatter
                    @markslatter13251
                    You must have posted as I was writing a reply, thanks for the reply David
                    #412001
                    Nick Hulme
                      @nickhulme30114
                      It's a shame it wasn't a useful native taper
