Thanks for the reassurance on that score, Jason.
Things aren’t totally straightforward at the moment. Although the file specifies 20mm for the bore, the gear I have from the printer has a bore of only 19.8mm. There is no way this will slide on to the mill’s gear shaft as is.
I set things up to bore out to 20mm on my lathe, closing the chuck jaws (gently!) on to the teeth of the smaller cog and pushing the big cog flat against the jaw faces, but encountered a problem: I couldn’t get the gear to run concentrically because the narrow gripping surfaces of the jaws on my 3 jaw chuck don’t all align with a gear tooth, but rather one jaw always wants to grip between two teeth. I’ve tried using the aluminium jaw covers I made for my four jaw, but it still won’t run concentrically. Needless to say, I didn’t attempt any actual boring.
I’m going to try the four jaw when I have time. Any tips meanwhile on how to hold a nylon gear for boring on the lathe would be appreciated.
