Deckel FP1 feed gears
Home Forums Beginners questions Deckel FP1 feed gears
  • #472874
    Paul Sims 2
      @paulsims2
      Hi Im looking for any information about the old type feed gears on the Deckel FP1, all I know that one set is 73 teeth and 27 teeth and that all the sets add up to 100 teeth. So any help would be appreciated.
      Paul Sims 2
        @paulsims2
        information about gears
        #472953
        DC31k
          @dc31k
          If you do not have any joy here, head on over to Practical Machinist forum as they have a Deckel sub-forum with a lot of very knowledgeable people. I believe Franz Singer in Germany is a (commercial) source for these machines.
          Do you have any gears at all? Anything shown in the online literature on the machine? If so, you could probably deduce the sizes of the missing ones from the relative feed ratios.
          #472966
          DC31k
            @dc31k
            Post number 8 here:
            https://www.practicalmachinist.com/vb/deckel-maho-aciera-abene-mills/alexander-toolmaster-deckel-fp1-clone-355790/
            gives the sizes for an Alexander, which is a Deckel clone and you are correct about the teeth total of 100.
            Put 'fp1 feed gears site:www.practicalmachinist.com' (without the quotes) into Google and you might hit paydirt.
            I have a hazy memory that there was someone on homeworkshop.org.uk this year cutting Deckel feed gear sets. The advert is gone but an 'information wanted' advert there might produce results.
            #472991
            Phil P
              @philp
              There certainly was a chap making batches of new gears for the Alexander Master Toolmaker which is basically a Deckel FP1, over on the "Home Workshop" website not too long ago.
              So I would think a wanted advert on there would yield results.
              If you have no luck, I can measure my set for you. They have a three tooth drive dog on one side.
              Phil
              #473024
              Paul Sims 2
                @paulsims2
                Thanks DC31K and Phil P thats just what I wanted. I only joined a few days ago and this was my first Question and what fantastic response posted at 9.40 am answered before 3pm. Thanks again Paul.
                #473783
                Rick Kropf
                  @rickkropf71033
                  Are you trying to determine the pitch and pressure angle of your existing gears?
                  Rick
                  #473947
                  Paul Sims 2
                    @paulsims2
                    Hi Rick, yes I was, I didn't have the gears when I asked for help but I have them now and it looks like I wont need them anymore the friend I was helping out is looking to add a variable drive now, as hes got the motor and etc and to be honest I was struggling a bit Ive only made about 6 gears in the last 60+ years 2 nylon ones for my lathe and 4 small 40:1 worm gear sets for dividing heads. So thanks for your offer help. Regards Paul
                    #473977
                    Rick Kropf
                      @rickkropf71033
                      Hi Paul,
                      I design and reverse engineer gears for a living. f you change your mind I can help you identify the gears.
                      Rick
                      http://www.flickr.com/photos/cube61/albums/72157613412567772
                      #488173
                      Richard –
                        @richard-3
                        Hi Paul, How did the feed with an extra motor go?
