Deburring Tools
Deburring Tools
Home Forums Workshop Tools and Tooling Deburring Tools
  • #99682
    Sub Mandrel
      @submandrel
      I usually debur with the edge of a bit of HSS, or If I want agoo finish, a small file.
      I thought I'd treat myself to a set of four proper deburrers (aluminium, brass/CI, steel, plastic). despite being small and incredibly cheap (4.10 for four with plastic handles from Arc Euro). The handles are abit naff, but actually have a clever twist lock and you can reoplace the inserts which are even cheaper.
      What I hadn't appreciated is that each tool has a different geometry and swivels to cut at a suitable angle without digging in to the softer materials. In use, its a bit like peeling a potato. only you get a very neat, consistent very narrow bevel on the corner. You can also trim back any slight raised edge, as on where a bandsaw cut was made.
      For such a simple item, i wish I had these years ago, they are also ideal for tidying up plastic kits, for example.
      Sub Mandrel
        @submandrel
        I’ve never used these before
        #99686
        martin perman 1
          @martinperman1
          Neil,
          I've been using these De Burrer's for years in both work and hobby, I tend to use one tool for every thing from plastic to steel with no detrement. I also have two ceramic tools which look like knives with square cutting edges which are also quite good.
          Martin P
