BTW…whats all this about throttling the primary to reduce the current ?
the primary of the trans former is already expecting mains ( assume mains transformer)…the current will depend (mostly) on the secondary load.. and if that is unconnected /used then the primary will idled with just enough current to saturate the iron in the magnetic circuit
now if you make your tool part of that magnetic circuit..you might well increase the primary current.. but it is most likely that the new arrangement will have a much lower requirement not higher.. ( talk of magnetising force susectability and permability follows……).. so
if you could
1 select "beefy" trans former…think pounds of iron…
2 saw slot in laminations to " cut" the magnetic circuit.. so that
3 the tool can be introduced in to air gap created in 2 above
4 a) idealy slowly ramp up hold and ramp down the current to demagnetise the tool..
4 b) alternatively, ( to 4 a) move the tool into and out of the air gap from infinity in each case…( for practical purposes 5 -6 times the diameter of tranformer coil)
me..? I wound a 1000 turn 2 foot long solenoid on 4" tube( thats only 300 m of wire) and fed it with 10 amps.(80 V).. before thinking about why my components were hairy…
why didn't I use the transformer trick from above?..ever seen a cheap redily available trand former that can have a 4" air gap added?
further thought.. readily avalable..CONTACTOR coils/solenoids …if big enough no fafing around disassebling transformers….
btw welder wires "hop" in just the earths field when you strike up…
Edited By jason udall on 04/07/2013 14:32:20
