Posted by KEITH BEAUMONT on 27/09/2022 21:02:33:
The question still remains that previous stalling did not remove any problem at the brushes. Also ,what were the sounds from the Power Supply when I hand stalled it? Thinking about it,
Keith
I believe the proposed brush problems the most likely – If the brush was stuck or had some guff between it and commutator, then contact might be 'OK' for low current, ie, low torque, and fail with load. Repeated stalls dislodged the guff or stuck brush.
The odd sound from the PSU – this could easily be due to the contact tween brush and comm coming and going as the brush made good contact and broke that a few times during the stall – the PSU would then PWM itself from high current to low current mode and back, in sync with the brush contact rate, and that is reflected into a more and less intense magnetic field in the PSU switchmode transformer, the resulting magnetostriction resulting in audible clicking.
I presume the PSU and motor were in close proximity – are you sure the audible sounds were from the PSU and not from the motor as the brushes made/broke contact?
PWM can change in real time, but only if the control loop commands it – this is inherent in the PSU – the loop is a closed one with the pwm dependant on output voltage.
The speed controller is another issue though – Basic PWM speed controllers are not closed loop and do not control torque or speed – simply set speed with a specific PWM width, and then any load will cause speed to drop, etc.
Better PWM speed controllers use motor back-EMF to measure motor speed and close the loop, but most cheapies don't. Even better controller measure motor current and back EMF and control the speed/torque curve.
What is the speed controller part number?
