Dusty,
Yes it’s 7 thou each side.
I think there are several options –
1/ Build as drawing and hope machining error, slop etc compensates.
2/ Build as drawing but modify hornblock/axle-box/axle to bring in 7 thou each side.
3/ Make everything that bolts to the outside of the frames 7 thou further away. (Shims?)
4/ Increase spacing between frames … and modify everything that bolts to the inside of the frames. (i.e Well tank supports, pump spacer, Draw Bars etc)
I think I would rather go with option 1 or 2 seems to be less work, if it don’t work I can always put shims under.
Must accuractly measure my frames … Blackgates say they are 3mm … a spray of primer would reduce the error
