Damp shed: what’s the best way to add ventilation?
Home Forums The Tea Room Damp shed: what’s the best way to add ventilation?
Viewing 25 posts - 1 through 25 (of 28 total)
  • #36792
    Simon Robinson 4
      @simonrobinson4
      Simon Robinson 4
        @simonrobinson4
        I have a 6 ft by 4 ft wooden tool shed with apex roof which gets very damp in winter. I’ve re-sealed the roof but there’s always dampness inside the shed despite being placed on a concrete patio on sleepers with reasonable space around it.
        Should the vents be on both ends of the shed just under the apex point or should there also be vents low down as well? Any other ideas?
        #590164
        DutchDan
          @dutchdan
          Advise I've read suggests placing one vent high and one low, the moist air is heavier and should exit from the lower vents. Not sure how much of a difference it'll make, but probably cheap enough to be worth a shot.
          #590166
          Baz
            @baz89810
            If it were me I would invest in a decent dehumidifier, dessicant one for preference and one that has a continuous drain facility.
            #590184
            Bazyle
              @bazyle
              Surprise ! the UK is damp in winter (and most of summer).
              If you make holes in a shed it will be damp. Best thing is to seal it up and just open the door after very frosty nights when the air will be dry and really hot days in summer. You especially don't want to open the door on a day when it has changed from cold to feeling warm because a wet warm front has moved over the country.
              #590190
              Dave Halford
                @davehalford22513
                What did you 'seal' the roof with? It should have been heavy duty felt, the expensive stuff. 6×4 sheds tend to be made cheap with the thin felt and thin walls made from fencing panel timber.
                Without gutters rain will run off the roof hit the patio and bounce up wetting the walls.
                #590197
                Ady1
                  @ady1
                  Posted by DutchDan on 16/03/2022 16:26:08:
                  Works for prairie dogs, so their burrows get ventilated
                  eek! eek!
                  #590213
                  John Haine
                    @johnhaine32865
                    A condensing dehumidifier would be good. Moist air is not heavier.
                    WHY IS MOIST AIR LESS DENSE THAN DRY AIR
                    AT SAME TEMPERATURE
                    METEOROLOGIST JEFF HABY
                    The units of density are mass divided by volume (m/V). Density will increase if either mass increases while the volume remains constant or if volume decreases while mass remains constant.
                    Density of air will vary as the temperature and moisture content in the air varies. When the temperature increases, the higher molecular motion results in an expansion of volume and thus a decrease in density.
                    The amount of water vapor in the air also effects the density. Water vapor is a relatively light gas when compared to diatomic Oxygen and diatomic Nitrogen. Thus, when water vapor increases, the amount of Oxygen and Nitrogen decrease per unit volume and thus density decreases because mass is decreasing.
                    The two most abundant elements in the troposphere are Oxygen and Nitrogen. Oxygen has an 16 atomic unit mass while Nitrogen has a 14 atomic units mass. Since both these elements are diatomic in the troposphere (O2 and N2), the atomic mass of diatomic Oxygen is 32 and the diatomic mass of Nitrogen is 28.
                    Water vapor (H2O) is composed of one Oxygen atom and two Hydrogen atoms. Hydrogen is the lightest element at 1 atomic unit while Oxygen is 16 atomic units. Thus the water vapor atom has an atomic mass of 1 + 1 + 16 = 18 atomic units. At 18 atomic units, water vapor is lighter than diatomic Oxygen (32 units) and diatomic Nitrogen (28 units). Thus at a constant temperature, the more water vapor that displaces the other gases, the less dense that air will become.
                    You may be familiar with the concept that moist air is less dense than dry air. This is true when both have the same temperature or when the moist air is warmer. Said in another way, air with a greater percentage of water vapor will be less dense than air with a lesser percentage of water vapor at the same temperature. Often people erroneously believe that moist air is denser than dry air because very moist air is more difficult to breathe than dry air.
                    #590253
                    David George 1
                      @davidgeorge1
                      I have a dessicant dehumidifier in my garage and it works great and provides a bit of background heat as well.
                      David
                      #590256
                      Jon Lawes
                        @jonlawes51698
                        I use a condensing dehumidifier which actually warms and defrosts itself if it gets too chilly. This is quite useful for providing water for steaming as well.
                        #590394
                        Howard Lewis
                          @howardlewis46836
                          Firstly, when the felt on the roof eventually failed, I replaced it with rubber. (Mine has a flat roof, faliing from 8' at the to to 7'6" at the back, over 6'9" ) It is 10' 9" long external, so not too big.
                          The materials, and trims came from Rubber for Roofs. I gave the dimensions and the site calculates the material needed Order placed in the afternoon, everything, (Rubber sheet, adhesive, trims, ring shank nails, arrived 0800 next morning ).
                          make sure that you position the nails correctly before hammering them in. They do not come out easily!
                          INSULATE! Line the inner walls, but put glassfibre or mineral wool insulation between the inner and outer skins.
                          If you can, insulate the roof in similar fashion.
                          My shop has no windows, and inner lining to walls and roof is 12 mm ply, on 50 mm framing, with glassfibre between.
                          On the back wall,there are two small fixed vents close to floor level, and a fixed vent near to roof level. This has an external hood to prevent any rain ingress, when the small, rarely used, intake fan is running.
                          The moist air will exit at floor level and fresh, hopefully, drier, air enter through the high level vent.
                          SECURITY
                          The door is a fire door, with a 6 lever lock. I wanted a 5 lever, but the door came with the 6 lever. The weight necessitated a 100 mm wall for the door end.
                          I made hinge bolts by turning the heads off three fairly hefty woodscrewss. they were screwed into place by using a drill chuck, until only about 18 mm protruded.
                          Partially closing the door marked the post to show where to drill the holes.
                          So, the lock will be difficult to pick, and the hinge bolts will prevent the door being lifted out if the hinge pins have been driven out.
                          HTH
                          #590407
                          James Alford
                            @jamesalford67616
                            I have a 17' by 19' wooden garage which is used as a workshop. Whether it is luck or not, I do not know, but it gets no damp or condensation.
                            The walls and doors have foil-backed bubble-wrap insulation stapled over them with flake board on top. The roof is unlined. There is a modest amount of ventilation under the eaves and around the doors which are a "comfortable" fit. There are also a couple of holes drilled in the apex.
                            The wooden floor is up off the ground, standing on beams. I put a sheet of plastic damp proof membrane over it and covered this with hardboard and those cheap inter-locking rubber mats.
                            Originally, I also lined the roof with polystyrene covered with hardboard. This was a major cause of damp and was soon removed.
                            It is not the warmest place on Earth, but it is dry and damp free.
                            James.
                            Edited By James Alford on 18/03/2022 09:21:43
                            Edited By James Alford on 18/03/2022 09:22:19
                            Edited By James Alford on 18/03/2022 09:22:43
                            #590437
                            Jon Lawes
                              @jonlawes51698
                              I think it's crucial to have free flow of air through that gap. Maybe that is what you've achieved.
                              #590566
                              James Alford
                                @jamesalford67616
                                Posted by Jon Lawes on 18/03/2022 12:00:03:
                                I think that you are right. I do have a small computer fan over the vent holes in the apex, intended for use if I a using any noxious materials in there, but I have yet to turn it on, as much as anything else because the whole building acts like a resonating box and it is surprisingly loud.
                                James.
                                #590581
                                  Interesting to read how damp air actually rises. The condensation problem on my metal roof was terrible, even with a dehumidifier. I used the metallic bubble film. It has a reputation for not being hugely effective compared to other insulation, but I wanted something that wouldn't lose me headroom and could go between beams and the roof as much as possible. It's been really effective, I used a version with self-adhesive strips on it, but ended up using a roll and a half of double-sided tape as well for about 20m^2.
                                  I'm hoping it will help keep things cool in summer as well.
                                  Peter Cook 6
                                    @petercook6
                                    My little 6 x 4 shed (used to store the mower, shredder and other potentially useful junk) used to get damp. I installed a couple of passive vents, one low at the back, one High at the front and a cheap solar powered vent in the door. That has kept it dry ever since.
                                    #590616
                                    Simon Robinson 4
                                      @simonrobinson4
                                      Posted by Peter Cook 6 on 19/03/2022 14:16:53:
                                      What sized vents did you use?
                                      #590617
                                      Simon Robinson 4
                                        @simonrobinson4
                                        Posted by Neil Wyatt on 19/03/2022 10:15:09:
                                        Never though about it but car roofs must get a lot of condensation between the upholstery and metal roof. I’m not sure how they prevent condensation in vehicles otherwise the ceiling would soaking wet most of the time.
                                        #590620
                                        Simon Robinson 4
                                          @simonrobinson4
                                          Posted by James Alford on 18/03/2022 09:21:24:
                                          James.
                                          I wonder if my mistake was painting the inside walls in white emulsion? It’s stops the wood from breathing and probably increases condensation as dampness can’t soak into the wood and evaporate through to the outside due to the paint. Both inside and outside are painted.
                                          #590621
                                          Simon Robinson 4
                                            @simonrobinson4
                                            Posted by Dave Halford on 16/03/2022 18:41:57:
                                            It’s tongue and groove panels but the felt is thin and poor and nailed on which I’ve had to paint tar over.
                                            I think my big mistake was painting the inside of the shed in white emulsion because the moisture can’t absorb into the wood and evaporate to the outside due to the paint layer and so it just condenses. The outside is also painted but with Cuprinol.
                                            #590624
                                            Roger Best
                                              @rogerbest89007
                                              Maybe, vents will help, small 6" ones will make all the difference.
                                              Condensation will form on any cold metal object, cold being relative to the relative humidity. So you won't remove the problem entirely but if you wrap up your equipment it will help a lot.
                                              Best option is the proper insulation with dehumidifier. A little heat will improve that "relatively cold" parameter.
                                              Good luck.
                                              #590629
                                              Roger Quaintance
                                                @rogerquaintance14196
                                                Nature abhors a vacuum, if the air outside is damp it will be damp inside unless you have dry heating, and by that I mean not propane which only makes the damp problem worse. Dehumidifiers will collect the moisture from the air making space for the next lot to come in, in short without heating you are on a good hiding to nothing and forever fighting rust.
                                                #590643
                                                Peter Cook 6
                                                  @petercook6
                                                  Posted by Simon Robinson 4 on 19/03/2022 15:00:31:
                                                  I used a pair of Activents (Activent Ventilation Solutions for Sheds – Condensation Solutions). They needed a 60mm hole in the wall, but have a cowl to keep out rain and an insect screen to keep out bugs (the gap under the door is however still available to them!).
                                                  Not sure if its the passive vents or the solar extractor that does the most good. The solar unit drags fresh air in most enthusiastically when the sun is shining and the air is fairly warm and dry, less so on dull damp days and not at all at night when the air is coldest.
                                                  #590672
                                                  Bazyle
                                                    @bazyle
                                                    Posted by Peter Cook 6 on 19/03/2022 16:50:23:
                                                    When the air is warm it is able to hold more moisture. Having drawn it into your workshop when it cools down it will drop it's excess moisture.
                                                    #590676
                                                    Peter Cook 6
                                                      @petercook6
                                                      Posted by Bazyle on 19/03/2022 19:13:40:
                                                      Agree on the physics, but the key factor is the sunshine which drives the ventilator. On sunny days the air is likely to be drier. Warm damp (rainy!) days tend to be dull and overcast – and the ventilator doesn't draw that air in nearly as enthusiastically.
