Dake engine article
Dake engine article
Home Forums Model Engineer. Dake engine article
  • #112236
    modeng2000
      @modeng2000
      Model Engineer No 4448 has a description of the Dake engine by Stewart Hart and at the end of the article on page 149 is To Be Cotinued.
      ME is now up to No 4450 but no sign of the rest of the Dake engine article.
      When can I expect it to be printed?
      modeng2000
        @modeng2000
        #112238
          You could always find it on the web, Think its on several sitessmile
          #112245
            Just had a look at No 4450 and that says the Dake will be in 4451.
            J
            #112255
            modeng2000
              @modeng2000
              Many thanks, I have only read the index the index of 4450.
              Stewart Hart
                @stewarthart90345
                Yes it will be in 4451
                Thanks for your interest John
                Stew
                #112286
                modeng2000
                  @modeng2000
                  Hi Stewart, reading of your efforts to make one of these engines is quite fascinating! I had not come across the Dake before you published. It will be interesting to see if it gets used to provide the power for other models.
                  Stewart Hart
                    @stewarthart90345
                    Her,s the video of how it works
                    <iframe width="420" height="315" src="**LINK**" frameborder="0" allowfullscreen></iframe>
                    Stew
                  Home Forums Model Engineer. Topics
