D-Bit Speeds and Feeds
Home Forums Workshop Tools and Tooling D-Bit Speeds and Feeds
  • #20293
    Mark Slatter
      @markslatter13251
      Mark Slatter
        @markslatter13251
        Hi all,
        Ive never had the need to use a D-bit until now and am quite proud of my first attempt at making one. We'll see if it actually cuts anything!
        I'd appreciate some advice on speeds and feeds for this. It's a 6mm d-bit, the difficult bit is I'm using this on a CNC lathe and will therefore not have any "feel" as to how its cutting.
        I was initially thinking 100rpm, and 0.05 mm/rev feed, with a 0.5mm peck to clear the chips and keep things cool. How does that sound?
        I should add, the pilot diameter is 5.9mm and the material is EN9.
        Edited By Mark Slatter on 15/05/2021 11:07:13
        #545178
        Anonymous
          Depends what material you're cutting. For brass I'd be running at 500rpm and 0.1mm/rev and I wouldn't peck. Essentially the D-bit is a single flute reamer. You want to go in and out in one smooth movement with no faffing about.
          #545180
          Mark Slatter
            @markslatter13251
            Thanks for the reply Andrew, the material being reamed is EN9. I'll get rid of the peck as you suggested.
            #545185
            Anonymous
              Ok, I'd drop the speed to 250rpm and feed to 0.06mm per rev and use flood coolant.
              #545188
              Mark Slatter
                @markslatter13251
                Excellent, many thanks ill give that a try
