Hi Terry
Thanks for your reply. I think that you have missed the point about experience. I am not out to offend you or anyone else though I may have, especially when speaking about experience being a powerfull determinant in what we see as being right. Our lives are very much governed by it.
“There is no confusion, they may be purchased here at Tracy Tools, ready made”
That Terry’s sell the item that matches you description does not make me incorrect. There are at least ten forms of twist drill on the market all of which may legitimately called twist drill by virtue of the fact that they drill and that there is a twist in their construction. There is a requirement on the part of the purchaser to specify which type he wants or he will just end up with a jobber drill, not a stub, second cut, masonry, tapping drill etc.
“The term D bit is a name given to a specific piece of equipment designed to cut on the front face and produce accurate, flat bottomed holes and make a good substitute for a reamer. “
I am not for a moment saying that the description you have given is incorrect. What I am saying is that the term D bit is very specific to a form, not a function. That a peice of material when ground and viewed end on has the form of a letter D. It is not specific about the use to which it is put as in the case of twist drill etc.
That Tracy tools sell the device you accurately describe only goes to support my argument about experience.
If we talk about an axe, we all know what the item is. We can talk about a pole axe, a double headed axe or any type of axe at all. All are covered under the idea of a peice of hard material which has and will support a robust cutting edge, attached to a shaft and swung to cleave the item at which it is directed. The only type of axe which is specific in regard to nomenclature is a Cleaver. Like the Drill, the name tells you what it does. The term Axe does not, any more than the term D bit tells you that it is “a specific piece of equipment designed to cut on the front face and produce accurate, flat bottomed holes “
Pole Axe tells you that some part of the axe will be a pole, like twist drill will tell you that somewhere in the construction of a twist drill there will be a twist.
There are several artices by Harold Hall in MEW – one in MEW 151 p 11 in which he calls for the making of a D bit with a 10 deg taper. It is designed to ream a hole to take an eleven deg. taper pin to act as a detant.
This does not fit with your definition of a D bit “a specific piece of equipment designed to cut on the front face and produce accurate, flat bottomed holes”? If it is not a D bit then what is it? One can say that because it is made to ream a hole, then it must be a reamer. But does it have the form which most people understand to be a reamer? It does not have multiple cutting edges, it is not a peice of silver steel that has been machined and ground obliquely to provide a single cutting edge. Instead, when viewed end on, it has the form of a letter D.
In MEW 156 p26, Mick Knights has photos of nine D bits, only one of which fits your definition.
I am not saying that Mick Knights or Harold Hall are right or wrong, just that your definition seems a little too narrow.
This has been a lively discussion, thanks for your input.
Lawrie
