hi all,
i am (attempting) a simple stirling engine, from plans in popular science (april 61). It calls for a displacer cylinder of 1″ conduit turned down to 0.010 wall. I am using a piece of old bicycle frame. However, as i turned it down, i found a crack along the seam. (about 1/2″ long).
Is it reasonable to attempt a repair? I could silver solder, braze, or weld (oxy), probably using a scrap of tube as filler. as its not the power cylinder, absolute concentricity doesnt seem important.
(I dont have any more tube from this source, and i would suspect that another piece would be just as likely to suffer the same defect, my first attempt i crushed in the chuck, the second i turned too thin and found a crack in that as well)
alternative sources of suitable tubing (in australia) welcome.
( i am planning on using an old asthma ‘ventolin’ inhaler as the displacer piston, its a little narrower than specified, is that a big problem? )
