Will,
You've started off a fascinating and VERY useful topic, so although I have no interest at all in building steam the whole thread (sorry!) is excellent. As someone else has already posted, please keep this thread open, your own comments and the replies are very valuable to me.
I too live in Switzerland, have done for over 20 years, and having married a Swiss lady it's permanent now – Passport, voting, taxes, the whole bit. I'm also in the German-speaking part, in the NW, about 20 mins out of Basel. Drop me a line (PM if you like, but note I'm overseas for about the next 3 weeks). Tell me where you are and I may be able to help you a bit re local suppliers.
But you're right, compared to UK, Swiss suppliers of our sorts of stuff, both tooling and materials, are pretty thin on the ground. One thing I have found (if it's an "emergency" and/or if you don't mind paying relatively high prices) is that odd stuff like small Metric nuts & bolts (1.5mm up, Fine & Coarse, hex head and socket head) can be found quite easily in local aeromodelling and RC car & helicopter shops. But as said the price of a packet of, say 10 off 2mm nuts and bolts in such places is pretty outrageous (as a mate of mine said "At least Dick Turpin had the decency to wear a mask!)
So I've tended to use UK suppliers and as above, send me a msg and I'll send you a list of reputable suppliers that I've dealt with on the net (usual disclaimers).
I did have about 1 week (I think it was) of "latheing" in my RAF 3 year aircraft engineer's apprenticeship, but that was only a week, and it was in 1961!
In other words, I'm very much a complete novice with my Chinese Minilathe, and as has already been said, the whole set up lacks rigidity (especially if you lock the toolpost down on top of a bit of swarf between toolpost and topslide bed – !).
So at risk of going OT I'd like to widen this thread a little further. please.
All the beginner's books and articles I've read make a great "Hoo Haa" about parting off. Maybe it's just beginners luck but (touch wood) I've never, ever, had a problem with this (using a thin-blade HSS parting blade bought for LMS in the US – again usual disclaimers), set up in the "usual postion" no revese direction and rear toolpost necessary for me). This is on ali, brass, MS, CI ("Meehanite"
, and silver steel – even on some hexs, not rounds.
BUT, OTOH, I'm always having HUGE problems with boring big (ish) holes, to the extent that virtually all my attempts in no way deserve the description "round".
I start off with going up in 2-3mm steps with decent twist drills in the tailstock drill chuck up to my max dia (13mm). Overhang on the larger sized (therefore longer) drills is a problem on the Minilathe so I do start off with a problem bore, especially if it's a deep hole. Even drilling from both ends doesn't help a lot.
But after that (and with great dread) it's out with the boring tools (HSS, round shank items that fit into a toolholder with a round hole in ti – again from LMS but since buying those I've seen precisely the same items advertised by loads of other suppliers).
So my first question is "What's the point of the round shank and the "holy" tool holder?" We're told so often to be careful with the various cutting edge angles, but looking end on, it's dead easy to "rotate" the boring tool before securing to virtually any angle and there's certainly no degree of angular accuracy there – it's just by eye.
Second, exactly the same is true when looking at the tool holder from above – you can set it at virtually any angle relative to the centre line that you like. Again it seems to be just eyeballing it.
So how do you set these tools properly please?
Never mind all your talk of mirror finishes, all my bores would make a ploughed field look like a high class putting green!
I do pay a lot of attention to minimum overhang (tool and workpiece) but whatever I do about angles and overhang, rpm and feed depth, I get lots and lots of chatter, lots of "tool dragging", and the deeper the bore the worse it gets.
Any suggestions greatly welcomed.
Krgds to all, and I hope you're soon better Will.
AES
