Depends on how good the bored finish is if you need to hone or not. – But in short a honed finish will always be better. If the boring has done a reasonable job leaving 1/2 – 1 thou I would say would be enough.
It would also depend on if you were using a cast iron or an O ring. A rougher surface would chew up the rubber / viton ring, while a cast iron ring would eventually hone the bore this might take a long time and still run the risk of the bore and ring ending up scratched.
Most people want a nice slow running engine on a wiff of air for demonstration purposes and not one running uber fast. Again a nice smooth bore will assist in this.
So in short I would hone which is going to give a better finish than even the best bored out cylinder. Especially if the cast iron is not 100% good as some is nicer to machine than others.
Nick
Edited By Nick_G on 27/02/2017 18:28:04
