Cycle computer from Wilko used as Rev counter
Home Forums General Questions Cycle computer from Wilko used as Rev counter
  • #73993
    The Merry Miller
      @themerrymiller
      I know this was dicussed some time ago but I can’t find the original thread.
      After fitting the AS-11G cycle computer, did anybody finally establish what the RPM range was?
      The instructions quote up to 300 rpm which is inadequate for a lathe or mill.
      I need to know before I take the item back to Wilko’s.
      The Merry Miller
        @themerrymiller
        #73997
        Roderick Jenkins
          @roderickjenkins93242
          I’ve had mine up to 3200 rpm. The resolution is quite poor at this speed, it goes up in steps of 20 or 30 rpm but I don’t consider that to be an issue, the resolution is quite good enough for me.
          cheers,
          Rod
          #74005
          Michael Cox 1
            @michaelcox1
            I have checked mine against a commercial hand held photo reflective tachometer and it is accurate up to at least 2200 rpm (the max speed of my lathe).
            #74006
            The Merry Miller
              @themerrymiller
              Thanks for that info lads,
              I’ll set mine up over the weekend.
              Len P.
              #74047
              The Merry Miller
                @themerrymiller
                Well it was all set up today and for the benefit of those lucky people with a Tom Senior M1 mill with a seperate vertical head with quill feed these are the readings I obtained.
                The drive motor was O.5 HP 4pole and 1420 nominal RPM.
                The head had a four step poly-vee drive and the readings were taken after 15 sec wait for stabilisation at each step.
                Results in RPM:
                280
                500
                900
                1680
                Thanks to those who recommended the Wilko AS-11G cycle computer.
                Len P.
