Cutting through steel/iron round bar
Home Forums Beginners questions Cutting through steel/iron round bar
Viewing 25 posts - 1 through 25 (of 25 total)
  • #213085
    David Brown 9
      @davidbrown9
      Hi, is it possible to cut through 16mm diameter round bar on a Sieg SX2 mini mill? I am not sure if it is iron or steel (I found it on the street a long time ago and thought it might come in handy!). How could I do this? It is not stainless steel as it is a bit rusty.
      I realise I need a metal cutting band saw but I don't have room, finding space for the mini mill was a struggle.
      I have an Evolution/Rage circular mitre saw but no way am I going to try to cut throught that thickness of metal with this, the sparks when cutting through much thinner hard metal are scary enough!
      David
      David Brown 9
        @davidbrown9
        #213086
          Hacksaw works for me.
          I suppose you could make several cuts across the bar with say a 6mm milling cutter but seems a bit wasteful of metal and costly on cutter ware. If its short lengths then stood vertically in the vice and sliced off with a slitting saw is another option.
          #213088
          Frances IoM
            @francesiom58905
            Before I invested in a near essential bandsaw I had a cheapie (from Screwfix) Evolution/rage mitre saw with carbide tips – 40mm steel was easy (tho use it outside the workshop as throws metal even further than flycutting) – did struggle however on 20mm stainless (which I had to mill down on an SX1) – 16mm is no problem on an SX1 just slower (use a small slotdrill to progressively cut a channel
            #213092
            John Haine
              @johnhaine32865
              Have you thought of using a hacksaw? 16 mm would only take a few minutes with a decent blade.
              #213103
              Paul Lousick
                @paullousick59116
                Use an angle grinder with a 1mm cutting blade. I have cut thru 50mm bar with one of these. Then clean up the cut surface on the milling machine.
                #213108
                Roger Provins 2
                  @rogerprovins2
                  I agree with John, just hacksaw it and it'll be done in five minutes.
                  #213146
                  Chris Evans 6
                    @chrisevans6
                    If you can control a hacksaw reasonably well then use "Allhard" blades. They last a lot longer than the generally available flexible ones. You will hacksaw 16mm bar without raising a sweat.
                    #213151
                    colin hawes
                      @colinhawes85982
                      An angle grinder, as Paul advises, is very quick at cutting steel bars and it doesn't matter how tough the steel is. I have a cheap one and it has done a lot of work. It's also a quick way of carving high speed steel toolbits to near the desired shape. I also use a bandsaw for most cutting off though. Colin.
                      #213153
                      Mike Clarke
                        @mikeclarke87958
                        I'm always reluctant to use abrasive cut off wheels in the workshop as not keen on the dust sticking to my oiled slideways. Noisy too.
                        I've cut many a 50mm slug off with a hacksaw – it's almost therapeutic and definitely good exercise! I find a little lubricant on the blade helps (tend to use Trefolex).
                        Cheers,
                        #213154
                        David Colwill
                          @davidcolwill19261
                          Even though I have a bandsaw (getting long lengths into it takes some rearranging), I still find a hacksaw with a sharp blade is the goto tool for anything less than 25mm.
                          As others have said sharp good quality blades are essential.
                          Regards.
                          David.
                          #213156
                            16mm is an all in one go job with a decent hacksaw blade.
                            When you get up to 2", take it in a few short sessions rather than all in one go.
                            X2 will go through anything, if you take muiltiple cuts.
                            Bob Youldon
                              @bobyouldon45599
                              Hello David,
                              When I first read your post I though you'd left a nought off and it should have been 160mm, but as many have suggested use a hacksaw, 24tpi X 12" blade, plenty of cutting oil, don't go at it too fast and keep your thumb out of the frame. When it comes to the larger sizes above 2" etc then a steady go with the hacksaw, turn the radio on, get yourself a comfortable stance, an 18 tpi blade, again plenty of cutting oil and away you go, it'll whizz through. My wife can't even cut bread straight, hopeless! Cutting things off straight is one of those aquired arts, me, I hate wood with a vengence!
                              Bob
                              #213171
                              Mick Henshall
                                @mickhenshall99321
                                Bob–my wife is exactly thr same with a bread knife, do they do it on pupose do you think just to get us blokes to do summat in the kitchen?
                                Mick
                                #213174
                                Ian P
                                  @ianp
                                  Posted by Mick Henshall on 19/11/2015 13:14:00:
                                  Mick
                                  Have you actually checked that the correct breadknife is being used? They are made in left and right handed versions (I'm serious) and using the wrong one is a recipe for making toast of the bread!
                                  Ian P
                                  #213225
                                  mark costello 1
                                    @markcostello1
                                    Groanwink 2
                                    #213231
                                    David Brown 9
                                      @davidbrown9
                                      I will use a hacksaw, it didn't occur to me that 16mm isn't actually that thick!
                                      David
                                      #213233
                                      norman valentine
                                        @normanvalentine78682
                                        When I worked as a teacher of Design Technology I often had kids ask me if it was possible to cut steel. To them it was the hardest thing in their universe. I have watched many people using a hacksaw, brisk cuts (60 per min) and light pressure seems to be the way to cut quickly and accurately.
                                        #213238
                                        John Rudd
                                          @johnrudd16576
                                          Posted by David Brown 9 on 18/11/2015 19:42:20:
                                          David
                                          I too have a Rage Mitre saw, the 14" tct bladed job……made for cutting through steel, I've used mine for cutting through 1/2" plate and 2" square bar…..
                                          Dont be afraid to use it and take your time….
                                          #213251
                                          Brian John
                                            @brianjohn93961
                                            I use an angle grinder with a cutting wheel but please do it outside as it can make a hell of a mess if you try to do it inside ! Obviously, you should always wear eye protection when using this tool.
                                            Edited By Brian John on 20/11/2015 06:21:37
                                            #213273
                                            Ian S C
                                              @iansc
                                              Use a hacksaw, take cuts at a steady 70 per min, but before you get set into your work, take a cutting stroke, just to see if the metal is soft enough to cut, if not either use the angle grinder, or the wheelley bin.
                                              Ian S C
                                              #213341
                                              john carruthers
                                                @johncarruthers46255
                                                >Have you actually checked that the correct breadknife is being used? They are made in left and right handed versions (I'm serious) and using the wrong one is a recipe for making toast of the bread!<<
                                                Depends which way the grain goes.wink
                                                (sorry)
                                                Does the OP have a lathe? just part it off?
                                                #213343
                                                  No lathe
                                                  #213441
                                                  Ian S C
                                                    @iansc
                                                    A large cold chisel, a large hammer, and an anvil, and someone to hold the chisel.
                                                    Ian S C
                                                    #213462
                                                    Circlip
                                                      @circlip
                                                      High tensile Stainless rusts.smiley
                                                      Regards Ian.
