Just reviving this old thread. First real go at using the lathe (at least first time making something for purpose) And was a bit disappoint at the smoke it was creating, seems pretty obvious it would be unwise to be breathing this stuff in, although I did today. I was cutting back 70mm from the end of a bit of 20mm dia bright steel bar to 15mm. I was told to apply a dab of cutting oil to the surface before each cut. It was fair smoking, The cutting could be described a bluish spirals.
I may be should have worn my forced ventilation ffp2 helmet that I use for wood tuning, (not sure if ffp2 is useful against smoke?) Creating ventilation could be a problem (unless I start using it a lot)
However I read this thread with great interest – as I was using a carbide cutter (or at least I think I was, brass coloured diamond shpaed bit), may be I need not have used any cutting oil (or may be just some for the final cut)
So to my question – Is it fairly agreed that not using any cutting oil is OK when using a carbide or tungstan Carbide bit on mild steel ?
and here it is (a new axle for a sack barrow) quite proud of it.
