Cutting oil and ventilation
Home Forums Beginners questions Cutting oil and ventilation
  • #656474
    Neil Frankton
      @neilfrankton16738
      Hi
      I am new to machine work and have been using Clarke cutting oil. I find it has given me a cough and made me feel a little wheezy.
      Has anyone any recommendations for a non-toxic cutting oil please? I presume by their nature oils are likely to be toxic. Do you guys recommend wearing masks when working with brass and aluminium (the only metals I have tried so far? I have the workshop door ajar generally but wonder if enough air is circulating. Perhaps I should consider an extractor system?
      Apologies if this thread appears multiple times – admins, I have tried twice before to post but it doesn’t seem to appear.
      Thanks
      NF
      Neil Frankton
        @neilfrankton16738
        Health concerns
        #656479
        Paul M
          @paulm98238
          I don't use cutting oil on brass and only a splash of WD40 on aluminium. I still use a soluble cutting oil on steel when using HSS tools if taking a roughing cut or drilling. As it is soluble there are no obvious fumes however there is the potential drawback of soluble oil on the ways etc. Never personally found that to be an issue.
          I am sure there will be others who have an in-depth knowledge of the safety of modern cutting oils. Most suppliers seem to emphasise they are non toxic.
          #656480
          Anonymous
            Neat cutting oils are intended to lubricate, not cool. So they tend to get used for high pressure cutting applications such as gear shaping. Soluble oils provide cooling (due to the water) but not much lubrication. I use soluble oils when machining, but only with HSS tooling. Both brass and aluminium are turned dry. Personally I'd bin the cutting oil and turn dry to start with.
            I have never worn a mask in the workshop and have never felt the need to do so. Neither do I have an extractor fan. The garage door isn't a close fit and that seems to be sufficient for air circulation.
            #656491
            Mike Hurley
              @mikehurley60381
              I had some of the Clarke stuff and I'm sure it is sold as safe & non-toxic, but I found it stank something awful in use and honestly believed ' breathing this stuff in can't be good for you ' and stopped using it pretty soon after.
              I'm not convinced it is any use anyway in the hobby environment. You don't need anything with brass and not normally with aluminium . If you're using the correct toolbits with steels again you won't normally need any (unless as mentioned before, your using more exotic materials.) So as Andrew says, I'd bin it and perfect your technique without it
              Regards Mike
              #656493
                I'm surprised hobby quantity cutting oil is causing a problem, so maybe it's something else.
                In the UK at the moment Hayfever, colds, and a new COVID variant are doing the rounds. (Don't panic, the COVID is a mild variant, only causing cold/flu-like symptoms and most of us are still vaccine protected.) And, rarely, some individuals are sensitive to the chemicals. Short or a rebreather, masks are unlikely to help because they catch particles, not fumes.
                Unless a lot of hard cutting is done, cutting fluid may not be needed at all. Brass and cast-iron are cut dry, and I cut Aluminium with occasional brushed Paraffin, or sprayed WD40. Cutting fluid is reserved for threading, in tiny quantities.
                The main purpose of cutting fluid is lubrication. It helps cool the tool too, but getting it too hot causes nasty fumes. In quantity, a flow of cutting fluid washes swarf away, so it isn't minced under the cutter.
                For bulk cutting suds are often more useful than cutting fluid. Applied in quantity, suds cool and wash swarf away. Lubricates too, but that's secondary. Suds is an emulsion of a little soluble oil in water. Water is cheap and an extremely effective coolant. The soluble oil provides lubrication and prevents rust.
                In the good old days suds was a serious health risk because nasty bacteria grow in soluble oil, and – before antibiotics – getting it in a cut could end in amputation or fatal sepsis. And it stinks. Modern suds contain disinfectants, but they don't last forever.
                As flood-cooling is messy I avoid using it unless a lot of steel has to be machined. And carbide inserts reduce the need for cooling somewhat because carbide can be run hotter than HSS.
                Industrially, mist systems are most likely to cause health problems, for which reason they are operated inside a sealed cabinet. Last time I read about it, industry (machine centres) seemed to be moving towards compressed gas systems. Something cold like liquid Nitrogen is sprayed accurately into the cut: the freezing gas blows swarf away and keeps the carbide cutter cool. There is no lubricant. A big advantage is it keeps swarf clean, greatly increasing the scrap value.
                How much cutting fluid are you using. Try reducing it dramatically! As for advice if cutting back causes different problems.
                noel shelley
                  @noelshelley55608
                  I take it since you talk of fumes that it is not soluable oil ? or that you do not have a flood system and are using it undiluted ? Ali and brass do not require the use of oils ! Cut dry and use this stuff for drilling or tapping. Noel
                  #656496
                  Bazyle
                    @bazyle
                    People are affected differently by fumes and dust and solvents and may develop new allergies from time to time. A small fan through a tube to direct fresh air towards your face may help, and in summer it may be possible to get a flow in one end of the workshop and out the other.
                    Brass – no cutting oil and if possible have some special tools with very little top rake (look that up f you don't know) as it tends to dig in.
                    Aluminium. Try to cut dry but if the material starts to stick to the tool at the tip brush on a little of whatever oily stuff does not affect you. If that smokes because of the heat slow down. Kerosene/paraffin has been commonly recommended (main constituent of WD40) as it evaporates to also cool but that will mean more fumes. You could try wax, Lard and tallow were used in the past when oil was an exotic substance but that goes mouldy.
                    Steel. Try dry of with minimal oil brushed on. Slow down if smoke is coming off (not because the tool can't take it but because of your possible allergy). You can get away with almost no lubrication but it does often help the finnish on the very last cut.
                    BTW avoid bronze for a little while until you have some experience – it bites.
                    #656517
                    Neil Frankton
                      @neilfrankton16738
                      Thank you for taking the time to reply.
                      It may be covid or another nasty bug as I now have a sore throat. I will take the advice given and bin the cutting fluid or at least, consign it to an unused shelf and forget it. The Clarke fluid does smell very strong and I don’t like getting it on my hands anyway. I didn’t realise brass was cut dry – that’s great advice and something I have learned. I am thinking of investing in an extraction system which would keep air moving in the workshop anyway.
                      duncan webster 1
                        @duncanwebster1
                        Keep it and use it for parting off, where it definitely helps
                        #656522
                        Oldiron
                          @oldiron
                          Posted by duncan webster on 14/08/2023 13:49:37:
                          thumbs up
                          #656531
                          Steviegtr
                            @steviegtr
                            I use it & it does stink a bit. The smoke sometimes drives me out for a while. Luckily I have a door that can be left open. Don't bin it as it is great for threading. I have been using it for about 3 years with only my usual smokers cough.
                            Steve.
                            #656539
                            bernard towers
                              @bernardtowers37738
                              I am quite surprised when people say cut aluminium dry with hss or carbide I have found that you can can get cold welding on the tip of the tool and the finish is not as good as when a splash of WD/Para is applied and still not as good as when using PCD tips there Bl***y marvellous , its a shame to touch your work afterwards!
                              #656540
                              noel shelley
                                @noelshelley55608
                                Steve beat me to it ! Do not bin it it will be good for taps and dies. or drilling. Noel.
                                #656542
                                Bazyle
                                  @bazyle
                                  Of course it might just be coincidence that you got the cough/throat from a summer cold at the same time as using the fluid. Or it might be how your body reacts to allergens. I tend to get a headache 24-36 hours after exposure as the real problem is the excess histamine my immune system produces – hence 'antihistamine' hayfever medicine.
                                  #656553
                                  Anonymous
                                    Posted by Andrew Johnston on 14/08/2023 08:45:10:
                                    Me neither – but I only use cutting fluids/coolants that are intended for the job. I never use the oft-recommended (here) WD40 since I can find no evidence that it's intended for that job and the MSDS makes no mention of it. Who knows what by-products are generated if it gets hot? (Not to mention it stinks).
                                    #656557
                                    Mark Rand
                                      @markrand96270
                                      Posted by bernard towers on 14/08/2023 17:08:31:
                                      Built-up-edge happens at certain speed ranges when cutting aluminium with HSS and carbide. The solution is to reduce the cutting speed until it stops, or (if you can) increase the cutting speed until it stops.
