Cutting oil
Cutting oil
Home Forums Suggested Online Resources Cutting oil
  • #69444
    keithmart
      @keithmart
      Does anybody know of a supplier of neat cutting oil, that will supply small quantities at a reasonable price.
      All the suppliers I have found so far only supply minimum quantities of 25 litres.
      A couple will supply 5 litres at about £30 plus carriage.
      The last litre I purchased lasted me 2 years!
      Keith
      Leeds UK
      keithmart
        @keithmart
        #69446
        David Clark 13
          @davidclark13
          Hi There
          Warco do oil in 1 litre containers, at least, they used to.
          regards David
          #69487
          keithmart
            @keithmart
            Hi
            They do but will not supply it on its own, without purchasing a machine at the same time.
            That would make it a bit too pricey!
            regards
            keith
            Leeds UK
            #73454
            georgie howell
              @georgiehowell11482
              Hi Keith
              I am sure you have got some cutting oil by now but we sell Ferrofluid in 0.5 litre bottles. You can buy online, no carriage and no minimum order. http://www.drill-service.co.uk regardsGeorgie @import url(http://www.model-engineer.co.uk/CuteEditor_Files/Style/SyntaxHighlighter.css);@import url(/CuteEditor_Files/public_forums.css);
              #98053
              mechman48
                @mechman48
                Machine Mart
                Cutting fluid – Ref order code 059930400 – 1 ltr – £ 8.39p cheers George
                #98056
                Ketan Swali
                  @ketanswali79440
                  #98058
                  Sub Mandrel
                    @submandrel
                    Machine marts is a little bit smelly. It lasts me years, I have a little pot-bellied jar that sits in a tin-lid drip tray with a toothbrush and an old paintbrush. These last a while until I manage to mill off the hairs.
                    I've got some cora-b from Reeves in 1L as well, but I don't think it is noticeably better, although it looks cleaner.
                    michael howarth 1
                      @michaelhowarth1
                      Tool Station sell a cutting oil for £4.29 a litre…..if £10 is spent, delivery is free. They call it broaching oil and describe it as high performance cutting oil. It works well for me.
                      #98061
                      michael howarth 1
                        @michaelhowarth1
                        Further to the above post, it is in the Automotive section of their catalogue for some strange reason.
                        #98069
                        ChrisH
                          @chrish
                          Warco now supply cutting oil without you having to buy a machine as well! I got some a few months ago – they said their carrier had now agreed to transport it. I think they do 2 and 4 litres containers from memory.
                          Chris
                          Edited By ChrisH on 09/09/2012 23:00:11
                          Edited By ChrisH on 09/09/2012 23:00:38
                          #98071
                          Martin W
                            @martinw
                            Your comment re brushes being bereft of bristles made me chuckle. I too have several wooden sticks with a metal ferrule at one end which started life as perfectly serviceable small brushes. Just a drop more cutting fluid towards the end of a cut and then suddenly its a tug-of-war with the mill and a bald brush blush oops. Still it goes with my hair line these days!!
                            Cheers
                            Martin
                            PS. And I thought it was just me that managed to screw it up!
                            #98072
                            Trevor Drabble 1
                              @trevordrabble1
                              Keith,
                              If you live any where near South Yorkshire, no problem in supplying your reasonable requirements free from me, but would apprecaite a donation to charity.
                              Trevor.
                              #98075
                              keithmart
                                @keithmart
                                Hi Trevor
                                Many thanks for the offer, but I am now sorted.
                                Keith
                                Leeds UK
                                #98088
                                Douglas Johnston
                                  @douglasjohnston98463
                                  Just had a look at the Toolstation site but no mention of broaching oil at £4.29 a litre. There is pipe threading oil at £6.63 a litre and tapping and drilling spray at about £3.50 a can. I have used the spray before on aluminium and it worked fine but a spray can does not last long. I may give the pipe threading oil a go for general machining and see if it is worhtwhile.The free carriage is a real plus with Toolstation, they can't make any money on small heavy orders.
                                  Doug
                                  #98093
                                  Robin King
                                    @robinking15611
                                    If you can find one (yellow pages ?) it's worth checking out any accessible agricultural suppliers – our nearest, TFM near Bridgnorth, stocks Morris Lubricants cutting oil in 5 litre cans at around £14.70.
                                    Robin
                                    #98110
                                    Dean Godfrey-Cooke
                                      @deangodfrey-cooke74440
                                      Hi Trevor
                                      I'm in South Yorks and am stuck for some cutting oil. I wonder if you could help me out, it doesn't have to be free, anything better than £8 from machine mart would be great 😀
                                      Thanks
                                      Dean
                                      #98114
                                      KWIL
                                        @kwil
                                        Toolstation, current catalogue (new one) Part No 67984 1Ltr Broaching Oil £4.29 inc vat
                                        #98119
                                        Douglas Johnston
                                          Yes very strange that the broaching oil appears in the latest catalogue but is not available on the website. Usually items will be listed even when out of stock, but not the case with this one.May no longer be available.
                                          Doug
                                          #98126
                                          michael howarth 1
                                            @michaelhowarth1
                                            Douglas …it is on their website in the Automotive products section.
                                            #98127
                                            michael howarth 1
                                              @michaelhowarth1
                                              I stand corrected…..it has been removed since earlier on today…..must have sold out as a result of this thread!
                                              #105679
                                              Takeaway
                                                @takeaway
                                                Hello Keith – I use ROTABROACH cutting oil by the litre from Ebay. Its light and doesn't stink when you put a cut on and it doesn't make your clothes stink either. I use it on my mini lathe and it keeps everything from going rusty. I reckon its good stuff and at £7.26 a litre (black bottle) with free postage it goes a long way, my bottle is 18 months old and still half full. I commend it to the house!———Stuart **LINK**
                                                #105680
                                                Nigel Rice
                                                  @nigelrice73086
                                                  Dean
                                                  When in industry, I always bought cutting oil and other lubricants from Millers Oils, Brighouse. OK, we were buying some oils in 50 gal drums, but they always supplied me with 1L bottles of oils if I wanted.
                                                  Very helpful company, worth a try if you can call in to collect.
                                                  Nigel
                                                  #105804
                                                  Brian Wood
                                                    @brianwood45127
                                                    Gentlemen,
                                                    For information and for those living North of York, Smith and Allan in Darlington sell soluble cutting oil in 5 litre containers, or larger, over the counter; they may also have the neat version as they are oil blenders.
                                                    I have no connection with them other than satisfaction with their products
