Thank you clive for your knowledge, that has helped very much.
i aligned the cutting tip up to a guage it was bit fidly but i got there in the end, i didnt check to see if the holder runs parallel with the cutting tip, i will check this later ,if it does i will remember this for future, it will be so much quicker, i did have a dummy run,looks good so far 2 more passes should do it, then for the real thing…
Thanks Garry
